#1 |
I bought this Stromberg at the Hershey swap meet and I have no idea what this is that’s mounted on it.
#2 |
Just a wild ass guess but a fitting for a gas heater? But I'm sure others will know for sure.
Making the simple complicated for over 30 years. |
#3 |
I was thinking the same, Southwind heater.
#4 |
That is the Stromberg specific fuel siphon for a Southwind. The fitting is probably as valuable as the carb.
#5 |
Is that sheet metal shield in front of the accelerator pump a standard Southwind part? Looks like a desirable safety feature to me, and probably harder to find than the fuel siphon.
#6 |
#7 |
Part of the mounting bracket. Not sure if it has another purpose though.
#8 |
I have that set up on my 35 with a
Southwind heater works great Mike |
#9 |
I have that same setup that came to me on a 94. Usually see a hole drilled in air horn above fuel bowl for a pickup tube. It has a special jet plug for fuel to be siphoned.
I dig coal, which provides motivation for EVs. |
#10 |
The extra hole in the top of many old carbs was drilled because they used the “universal” siphon kit.
#11 |
Here is the set up I discovered on my Southwind equipped car the day I brought it home. I removed all that plumbing and run with no heater. The Southwind still resides in the car, but it is not hooked up.
#12 |
Here you go!!!
#13 |
#14 |
Thanks to all that commented…
