Old 08-25-2024, 09:57 AM   #1
sidevalve8ba
sidevalve8ba's Avatar
Default Interesting crack repair video.....
I saw this crack repair video on the HAMB. Had to bring it over to my friends here on The Barn.
https://youtu.be/evML7xAo0bM
sidevalve8ba is offline   Reply With Quote
Old 08-25-2024, 12:27 PM   #2
Ronnie
Ronnie's Avatar
Default Re: Interesting crack repair video.....
Direct link https://www.youtube.com/watch?v=evML7xAo0bM&t=1s
R
Ronnie is offline   Reply With Quote
Old 08-25-2024, 12:54 PM   #3
19Fordy
19Fordy's Avatar
That is a great video. Provides good incite as to why automotive machining is expensive, time consuming, and requires a great deal of skill with top notch machines and machinists with problem solving ability. Wonder what that particular amount of work cost?
Thanks for posting.
Old 08-25-2024, 04:10 PM   #4
leon bee
No time right now, but I'm looking forward to watching this after my dinner. Thanks.
leon bee is offline   Reply With Quote
Old 08-25-2024, 07:16 PM   #5
cadillac512
cadillac512's Avatar
That's how it's done! Nice work.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 08-26-2024, 10:08 AM   #6
Bored&Stroked
Bored&Stroked's Avatar
I watched the video - the only part that I disagree with is that he didn't pin the transfer area. It would have only needed about 3 additional pins, but it might also prevent the crack from seeping water later on. There is water under the transfer area as it cools the valve pocket area.
Old 08-26-2024, 10:39 AM   #7
Planojc
Planojc's Avatar
Great video.
Planojc is offline   Reply With Quote
Old 08-26-2024, 10:42 AM   #8
flathead4rd
flathead4rd's Avatar
This is an amazing video and it is dealing with exactly what I am working on now. Couldn't have come at a better time in my rebuild dealing with cracks in blocks and how to deal with them. Thanks Ronnie for posting the link to it.
flathead4rd is offline   Reply With Quote
Old 08-26-2024, 01:02 PM   #9
leon bee
I guess now we need someone to assemble that engine and run it.
Old 08-26-2024, 04:35 PM   #10
GB SISSON
GB SISSON's Avatar
I really enjoyed the video too. Suddenly crack repair is less mysterious and seems practical for us 'stay at home mechanics.'
Old 08-26-2024, 04:46 PM   #11
Bored&Stroked
It is important to note that you must use the special taps that come with the kits. Also, you can order the "pins" in quite a few different sizes.
Sometimes you'll get a slight bit of air weeping around a pin (as shown later in his video). While one can continue to solve every last little bit - it isn't always necessary. I always use a can of Moroso Ceramic Seal when a repaired engine like this is first ran - as another level of insurance.
Old 08-27-2024, 12:02 AM   #12
Eagle43
This video came at a good time for me and I watched it with interest. I fixed 2 similar cracks in my 8BA block a couple of years ago. (https://www.fordbarn.com/forum/showt...hlight=Eagle43). I got the truck finished last fall and the motor ran fine on two outings. Earlier this summer it suddenly lost power and ran rough. After trying all sorts of solutions and narrowing it down to having no compression in cylinder #2, I finally pulled the head and discovered that the hardened valve seat I had installed had come loose and was rattling around. The fixed cracks seem to be holding up fine and are almost invisible. I bought a new valve and valve seat and am waiting for the Permatex 64000 high temperature sleeve retainer I ordered online. I think this is the stuff they were using in the video. Loctite 640 should be similar.
Eagle43 is offline   Reply With Quote
Old 08-27-2024, 10:05 PM   #13
Eagle43
My Permatex Sleeve Retainer came today and I installed the hardened valve seat with this stuff. Tomorrow I plan to grind and lap the valve and put everything back together. Hopefully this seat will stay in place. It seemed to go in there pretty snug.
The first picture shows the installed seat. I've already beveled the inside a bit using my wood lathe. The second picture shows the inside of cylinder #3 which looks good. The third picture shows cylinder #2, the problem one. This one had the deepest crack in the cylinder wall with some distortion and gave me the most trouble cleaning up and trueing the cylinder wall without putting in a sleeve which I'm not capable of doing. The yellow spot is where I ground out a bit too much. I know it's not perfect but I hope things hold together and I get enough compression in this cylinder. Hope to drive the truck this weekend.
Old 08-29-2024, 08:33 AM   #14
Joe B.
Joe B.'s Avatar
Fascinating video. Why is the iron so thin where the crack occurred between the valve pocket and the water jacket? Are they all like that? Is it due to casting variations?
thread killer
Joe B. is offline   Reply With Quote
Old 08-29-2024, 04:56 PM   #15
cadillac512
They're all pretty thin there. Just not a lot of room for both the port and water to cool it.
Old 08-30-2024, 10:34 AM   #16
rotorwrench
rotorwrench's Avatar
They cool better if the casting is thin. The model B engines may have been too thin around the valves. They crack a lot easier than the model A engines do. The V8s have always been problematic with cracking if the engine is overheated too much. It pays to keep the cooling system in top condition.
Old 08-30-2024, 12:23 PM   #17
Joe B.
Joe B.'s Avatar
Great site. Great info. I pick up some new knowledge everyday.
thread killer
Old 08-30-2024, 12:46 PM   #18
vincent
[QUOTE=Eagle43;2333738]My Permatex Sleeve Retainer came today and I installed the hardened valve seat with this stuff. Tomorrow I plan to grind and lap the valve and put everything back together. Hopefully this seat will stay in place. It seemed to go in there pretty snug.
While I do hope that your valveseat stays where it belongs I would not bet on it.
The seats are always a shrink fit, so it would not go in the recess without heat and / or force. On an Aluminium Engine it would be 1/250 of the diameter of the seat for correct overlap, on an Iron flathead I use 1/300 as the seat expansion and engine expansion rate are almost the same. That means the seat is always a bit bigger than the recess and will be unable to move.
vincent is offline   Reply With Quote
Old 08-30-2024, 10:06 PM   #19
Eagle43
[QUOTE=vincent;2334247]
I had the seat in the freezer just before I hammered it into place. It took quite a bit of force to get it to seat.
