Old 07-01-2024, 09:38 AM   #1
FrankWest
FrankWest's Avatar
Default 1933 MODEL B starter switch?
My starter does not have this. How is this starter switch connected to the floor switch?
FrankWest is offline   Reply With Quote
Old 07-01-2024, 10:25 AM   #2
DavidG
DavidG's Avatar
Default Re: 1933 MODEL B starter switch?
Nor should it have one. That was used on '32 fours until the change from a cable-activated switch to the foot-operated switch, the same as V8s.
Old 07-01-2024, 11:03 AM   #3
FrankWest
FrankWest's Avatar
Thanks
I have a spare model b engine that has a starter with this switch.
I guess I cannot use that starter on my existing car.
I have been having problems with my starter. I guess it needs rebuilding, because if the rotor happens to stop in a dead area I can't get the starter to run. I guess hand cranking the engine will not spin the starter to an active portion of the armature.
Old 07-01-2024, 11:12 AM   #4
Newc
Newc's Avatar
I found all those correct parts at Third Gen. Switch, cables, clamps, ect. Newc
Old 07-01-2024, 11:21 AM   #5
FrankWest
FrankWest's Avatar
Thanks
Old 07-01-2024, 11:22 AM   #6
FrankWest
FrankWest's Avatar
Third Generation is a great place, they have almost everything.
Old 07-01-2024, 11:31 AM   #7
petehoovie
petehoovie's Avatar
Old 07-01-2024, 02:35 PM   #8
FrankWest
FrankWest's Avatar
https://www.youtube.com/watch?v=Bu-A8YfC4w0
Old 07-14-2024, 07:07 AM   #9
FrankWest
FrankWest's Avatar
Can I swap out the internals of this 1932 starter for use on my 1933 starter Model B if I need to?
Old 07-23-2024, 09:38 PM   #10
mvee33
Right hand drive 1933/34 Bs have a starter motor pull cable from the dash, and switch as above.
mvee33 is offline   Reply With Quote
Old 07-24-2024, 12:12 AM   #11
DavidG
DavidG's Avatar
Not surprising as its part number is BF-11450 which was originally first released for '32 RHD fours.
Old 07-24-2024, 02:03 PM   #12
FrankWest
FrankWest's Avatar
I have a replacement starter from Third Generation on the way.
Once I get a working starter in my car then I can begin looking at the distributer. I
