Old 07-01-2024, 02:39 AM   #1
Aussiebill
Default How does the Knob go onto the Hood Cable on a 46 Ford
How does the Knob go onto the Hood Cable on a 46 Ford, is it just a matter of pushing it on, I have waited 6 months for this T Handle Knob so I don't want to mess it up.
Thanks in advance
Bill
Aussiebill is offline   Reply With Quote
Old 07-01-2024, 06:40 AM   #2
51woodie
51woodie's Avatar
Default Re: How does the Knob go onto the Hood Cable on a 46 Ford
I had to replace the T-handle on my ‘46, as one side of the T was broke off. I broke off the rest of it with wire cutters, and the hole in the new one was the right size to let it fit over the pull cable. I used 5 Minute Epoxy to secure the handle to the cable.
51woodie is offline   Reply With Quote
Old 07-01-2024, 09:19 PM   #3
Graeme / New Zealand
Graeme / New Zealand's Avatar
New Zealand assembled 46 to 48's used the same metal T handle that was on Mk1 Zephyr's. It has the word "hood" embossed on it and attached by a grub screw.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 07-02-2024, 07:47 AM   #4
Aussiebill
Thanks Guys
I will use the 5 Minute Epoxy method.
Unfortunately mine does not have a grub screw
Regards
Bill
Old 07-02-2024, 08:40 AM   #5
woodiewagon46
Bill, I'm not sure that 5 minute epoxy will do the job. The hood release has a bit of resistance and if the knob or T handle comes off then you have a bigger problem.
woodiewagon46 is offline   Reply With Quote
Old 07-02-2024, 09:15 AM   #6
Lanny
Lanny's Avatar
J-B Weld Two Part Epoxy - World's Strongest Bond
J-B Weld
https://www.jbweld.com
Multipurpose epoxy & adhesives that provides strong, lasting bonds on almost
anything...
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 07-02-2024, 10:45 AM   #7
tubman
tubman's Avatar
I'd run an appropriately-sized coarse tap down the hole in the handle and put a couple of crimps in the wire to give the epoxy something to "grip" on.
Old 07-02-2024, 12:26 PM   #8
woodiewagon46
Tubman, excellent idea, a straight pull with a smooth hood release wire and a plastic knob won't last long.
Old 07-03-2024, 08:35 AM   #9
Aussiebill
Thanks guys for all the replies and ideas, I do have some JB Weld in the shop. When you buy a new cable like I did, the Hood Pull handle or knob is separate with no instructions, you would think it would be a simple task of pushing it on but maybe it comes of just as easy, so that's why I asked the question running a tap down the knob hole sounds good as does crimping the area where the knob goes on. Thank you Bill
