Old 06-04-2024, 01:07 PM   #1
rottenron36
rottenron36's Avatar
Default 1940 master cylinder repair kit
My 1940 master cylinder was apart. Got a rebuild kit that has a rubber washer in it. None of the diagrams show it, where does it go? Thanks Ron
rottenron36 is offline   Reply With Quote
Old 06-04-2024, 02:31 PM   #2
glennpm
glennpm's Avatar
Default Re: 1940 master cylinder repair kit
There is no rubber washer. The "piston stop" is a steel washer.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 06-04-2024, 02:45 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
the rubber washer goes in first under the residual pressure valve,then the spring etc.
Old 06-04-2024, 02:55 PM   #4
rottenron36
! yes, 1 no, on the rubber washer that came in the kit. Help! Thanks Ron
Old 06-04-2024, 03:31 PM   #5
Bob C
How about a picture of it or the size.
Old 06-04-2024, 03:46 PM   #6
rottenron36
same size as the bore, about 1/8 thick, hole in the middle
Old 06-04-2024, 09:52 PM   #7
cadillac512
cadillac512's Avatar
As Kurt said above, the washer goes in the cylinder first, and sits at the very bottom of the bore...clear at the end. Then the check valve and spring, cup and piston. The washer's job is sealing the check valve to the end of the cylinder.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 06-05-2024, 07:14 AM   #8
rottenron36
Thanks Kurt and Cadillac for your response, you got me on the right track!!!! Ron
Old 06-05-2024, 09:13 PM   #9
Bruce in southern OH
Bruce in southern OH's Avatar
Where did you purchase your rebuild kit, thanks
Bruce in southern OH is offline   Reply With Quote
