Old 04-23-2024, 09:21 PM   #1
qmdv
qmdv's Avatar
Default Generator and Fan
I have a generator and fan assembly that I do not know what it is off off. I think it a good idea to identify it before I put it up for sale. The pully is 3 3/4 inch diameter. All the others I have are just over 4 1/4. Could it be off of a 60HP engine?
Oh the fan is like most others I have
qmdv is offline   Reply With Quote
Old 04-24-2024, 06:20 AM   #2
ndnchf
ndnchf's Avatar
Default Re: Generator and Fan
There are many different generators, pulleys and fans. Please post a few clear photos of it. I can probably tell you more with photos.
ndnchf is offline   Reply With Quote
Old 04-24-2024, 11:43 AM   #3
19Fordy
19Fordy's Avatar
Yup, please post plenty of photos of your fan assembly.
Old 04-28-2024, 10:25 AM   #4
qmdv
qmdv's Avatar
I assumed that a V8-60 had a smaller crank pully. And that they would have a smaller fan/ generator pully to achieve the same fan speed
Old 04-28-2024, 10:30 AM   #5
ndnchf
ndnchf's Avatar
Yes, V8 60 has a smaller crank and generator pulley. I looked through my spare pulleys and found one V8 60 pulley. They are hard to find and identify. There are two, maybe three different V8 60 pulleys.
Old 04-28-2024, 01:44 PM   #6
petehoovie
petehoovie's Avatar
Old 04-28-2024, 04:00 PM   #7
Terry,OH
Terry,OH's Avatar
Appears like the 33-35 Generator. If you clean the body you will find a date code. The pulley usually has a part number as well as the front mounting embossed into the metal.
Old 04-28-2024, 04:08 PM   #8
DavidG
DavidG's Avatar
Mke that '34-'36 as an original '33 V8 generator does not have a vented front bracket.
Old 04-28-2024, 04:41 PM   #9
Kube
Super Moderator
Kube's Avatar
Why would a 60HP have a smaller pulley than the 85HP? Both have identical 6v electrical systems and both need to charge at the same rate.
In 1940 there were two different pulleys. The first (early) design was larger in diameter than the later design.
That had nothing to do with 60 or 85 applications.
Old 04-28-2024, 05:44 PM   #10
ndnchf
ndnchf's Avatar
I don't know, I'm not an engineer
There were a lot of different pulleys available over the years. A mid - late 1930s car with big V8 typically used a pulley .408" to .438 diameter. The V8 60 used a 3.68" diameter pulley in '37. In '38-'39 it could be either 3.71" or 3.40" diameter pulley. In 1940, the 01A-1000-B V8 60 generator used either a 3.12" or 3.18" diameter pulley.
On the left is a 1937 V8 60 pulley, 3.68" diameter. PN BB-10130-B. On the right is a big V8 pulley 4.38" diameter. PN 68-10130-C.
Old 04-28-2024, 05:56 PM   #11
Kube
Super Moderator
Kube's Avatar
I'm guessing you are getting your information from a Ford parts book. Am I correct?
If you are, you must keep in mind, the parts listed are for service and in many cases Ford "made do" with what worked.
In 1940, there were two pulleys regardless of vehicle application. The first design was 3 11/16" diameter. The later design was 3 3/16" diameter.
I'm not certain where you got 3.12 and 3.18. Do you really think Ford made two pulleys that were a mere .060" different from each other?
Old 04-28-2024, 06:01 PM   #12
ndnchf
ndnchf's Avatar
It does seem odd, but I'm reading this out of the Ford geen book. Just reporting what I read.
Old 04-28-2024, 06:05 PM   #13
petehoovie
petehoovie's Avatar
Old 04-28-2024, 07:38 PM   #14
Kube
Super Moderator
Kube's Avatar
I kinda thought that's where you were getting your information.
Old 04-29-2024, 06:11 AM   #15
Terry,OH
Terry,OH's Avatar
The BB- pulley is smaller because big trucks usually do not operate at high RPM the smaller pulley will increase generator output at lower RPM keeping the battery charged.
Old 04-29-2024, 10:11 AM   #16
Ol' Ron
Ol' Ron's Avatar
Never use a generator or mechanical fam. Always use an Alternator and electric fan Last forever, works great.
Gramps
Old 04-29-2024, 10:41 AM   #17
Tim Ayers
Gramps
I guess and I get it, but they seem to look out of place in my opinion.
Old 04-29-2024, 03:02 PM   #18
qmdv
qmdv's Avatar
Gramps
Who makes a decent looking electric fan for a 32 roadster
Old 04-29-2024, 11:03 PM   #19
Ol' Ron
Ol' Ron's Avatar
Generally speaking, I wasn't talking a hotrods, where esthetics are more important.
Gramps
Old 04-30-2024, 06:47 AM   #20
Terry,OH
Terry,OH's Avatar
Many generators found recently are an amalgam of pieces from various years so it can become impossible to identify from appearance especially covered in dirt. The 33 does not have vent holes in the front mounting bracket and the 36 armature does not have a 5/16" threaded attachment for the pulley
