Old 04-01-2024, 09:48 PM   #1
31deluxe
Default Looking for PICTURES of headlight wiring eliminating springs.
Looking for pictures of how 30\31 headlights are wired eliminating spring connections.
If spring connections are replaced with bullet ends on the bucket side. What holds the conduit in place. That little dimple/pimple does not seem to be enough to hold the conduit in place without spring tension.
What am I missing?
31deluxe is offline   Reply With Quote
Old 04-02-2024, 10:40 AM   #2
katy
katy's Avatar
Default Re: Looking for PICTURES of headlight wiring eliminating springs.
Maybe put a cable tie around the dimple/pimple inside the headlight bucket?
Old 04-02-2024, 10:57 AM   #3
JayJay
I removed the core from the socket and reinstalled the socket, then installed bullet ends and push connectors for the wires. Have had no issue with the conduit falling off. You could squeeze the conduit head slightly to make it a bit out of round, it would grab onto the headlight socket that way.
Both the wires (high beam and low beam) coming from my (likely repop) bulb socket were black. I used colored tape to identify which goes to the black/red wire and which goes to the black/yellow wire.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 04-02-2024, 02:14 PM   #4
31deluxe
Thanks for the suggestions and pictures. Hoping for some warm, dry weather in NY soon.
Old 04-02-2024, 03:40 PM   #5
Planojc
Planojc's Avatar
Use a dab of RTV silicone
Planojc is offline   Reply With Quote
Old 04-03-2024, 11:01 AM   #6
Phil Brown
Phil Brown's Avatar
X2 on the little dab of silcone, holds well and easy to remove when you have to
Phil Brown is offline   Reply With Quote
