Old 11-15-2023, 09:31 AM   #1
divcoone
divcoone's Avatar
Default Pop out ignition
Should the key be able to be removed in both positions?
Bob Giles
divcoone is offline   Reply With Quote
Old 11-15-2023, 09:41 AM   #2
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Pop out ignition
The key can be removed from an Electrolock Popout Switch with the button in or out, so the key can be removed while driving. Also note that when the button is in to turn the ignition OFF, the switch grounds the ignition system to prevent stealing the car.
Bob Bidonde
Bob Bidonde is online now   Reply With Quote
Old 11-15-2023, 11:31 AM   #3
Jim Mason
Jim Mason's Avatar
If you mean popped out or pushed in yes.
If you mean turned, no
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
