Old 09-05-2023, 06:40 PM   #1
elmo771
Default 56 ford engine swap
Hello new here and my first post, I am going to pickup a 56 2dr sedan next week, It is a 6 cyl and was wondering what mounts to use in put in a sbf 302
elmo771 is offline   Reply With Quote
Old 09-05-2023, 07:30 PM   #2
paul2748
paul2748's Avatar
Default Re: 56 ford engine swap
These are mounts that I've been told work:
Anchor 2725 and 2726 - 84 Lincoln
Also 76 F150 302 mounts.
64-65 Galaxy 289 (might have to use a short spacer with these)
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-05-2023, 08:54 PM   #3
miker98038
miker98038's Avatar
There’s a 52-59 Ford social group over on the HAMB. If you don’t get the info here, try over there.
You may need to join to access that. If so, read the rules closely, and if you’re using an EFI motor don’t mention it. They are very strict about following the rules. You also get better advice by doing a short proper introduction.
Jalopy Journal and the HAMB are owned by Ryan, who also owns this site.
miker98038 is offline   Reply With Quote
Old 09-06-2023, 07:53 PM   #4
paul2748
paul2748's Avatar
The 52-59 Social group doesn't care about, stock, modified etc. Just the HAMB part (old school rods) care about that. Nice guys on the social group, I am member. You got to join the HAMB first, then go to the social group
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-06-2023, 08:43 PM   #5
elmo771
I also joined that group, A swap is going to be down the road
Old 09-15-2023, 02:25 PM   #6
darrell
ive done this swap.i use 302 truck mounts.you need to shim the bolts on the block 1/2 inch or it will set to low.there is another mount you can use but i never tried it.
darrell is offline   Reply With Quote
Old 09-15-2023, 02:43 PM   #7
elmo771
do you know what year
Old 09-15-2023, 08:24 PM   #8
darrell
all 302 truck mounts are the same until 79 at least.i dont think they ever changed.
Old 09-16-2023, 02:22 PM   #9
JeffB2
JeffB2's Avatar
Pictures and part numbers, be sure and read all the notes below. https://www.jalopyjournal.com/forum/...2.24352/albums You do have an advantage by swapping out the Six, the six cylinder cars have the radiator mounted further forward this helps with fan to radiator clearnce.
JeffB2 is offline   Reply With Quote
Old 09-16-2023, 02:31 PM   #10
JeffB2
JeffB2's Avatar
Originally Posted by darrell View Post
I've done this swap. I use 302 truck mounts. You need to shim the bolts on the block 1/2 inch, or it will set too low. There is another mount you can use but I never tried it.
Use the mounts I posted below, and you won't need to do that, also There are two brands of headers that you can use with zero clearance issues. Hedman 88400 and Patriot H8433. Swaps in a 1954-56 Ford will require the early front sump oil pan and timing cover used before 1980,the later 302/5.0's used a dual sump oil pan and have a driver's side dipstick which is what you want if the swap was going into a 1949-53 car.
Old 09-16-2023, 02:36 PM   #11
JeffB2
JeffB2's Avatar
I founded the HAMB 1952-59 Ford Group back in May 1994 all the Swap info can be found in a HUGE file the "Sticky FAQ" all the information was member submitted, DO NOT ask questions there it is an information file only, use the regular board for any questions.
Old 09-17-2023, 03:09 AM   #12
darrell
using the truck mounts you dont have to grind out between the bolt holes.your choice.
Old 09-17-2023, 03:49 AM   #13
JeffB2
JeffB2's Avatar
In most cases you do not need to slot the mounts, but there was no computer accuracy in the 1950's and so we suggested slotting because some members that did the swap found slightly offset holes, when I did my '54 I only had to elongate one hole slightly on the passenger side, you can always do a trial fit and hope you get lucky. I covered that in the notes under the pictures.
Old 09-30-2023, 04:49 PM   #14
Aarons56Sedan
Hi, this is my first post. I just bought a 56 Customline Fordor. The person I got it from had no knowledge about the car. They just inherited it. I have no idea which motor it has in it. Is there any identifying info on the block that will tell me which V8 it is. Based on pics I’ve seen, it appears to be the original motor and automatic transmission. Thanks
Aarons56Sedan is offline   Reply With Quote
Old 09-30-2023, 06:28 PM   #15
JeffB2
JeffB2's Avatar
Full details with pictures are here. https://www.youtube.com/watch?v=g8uukADyczM Be sure to read the comments under the pictures. You have an advantage since you are replacing a Six, the radiator mounts are further forward giving you more clearance.
Old 10-01-2023, 06:46 AM   #16
elmo771
Thanks But the link doesn't work.
Old 10-03-2023, 03:20 PM   #17
JimNNN
Is there something drastically wrong with the current engine's condition? Worn rings or something? If not, I'd encourage you to keep the 6 in that car if that's how it was originally equipped.
If you want more power, I don't think there is a shortage of '56 Fords with V-8's for sale.
JimNNN is offline   Reply With Quote
