Old 07-31-2023, 11:57 AM   #1
flatman
flatman's Avatar
Default 59A adjustable lifters having wear problem
Valves were getting increasingly noisy. When re-adjusting lifters, found some
had uneven wear. Turning lifter in the bore would yield a different reading. More than 10 thousandths in some cases. Lifters are obviously shot. If i replace lifters, can i get away with not changing cam....Also where should i look for adjustable lifters. I know some people say the new ones have adjusters that wont stay put. thanks for any advice
flatman is offline   Reply With Quote
Old 07-31-2023, 12:43 PM   #2
Karl Wolf
Karl Wolf's Avatar
Default Re: 59A adjustable lifters having wear problem
The answer is "maybe".
You need to look at the cam closely.
It's a bit expensive to try, consider the worn lifters might have worn the cam.
Replacing the cam might be the best way to go.
Karl
Karl Wolf is offline   Reply With Quote
Old 07-31-2023, 02:23 PM   #3
Ronnie
Ronnie's Avatar
^^^^^^ I agree
Otherwise it could become an expensive venture.
R
Ronnie is offline   Reply With Quote
Old 07-31-2023, 03:24 PM   #4
Kube
Super Moderator
Kube's Avatar
Also, be certain the have the hardness of each and every lifter checked professionally. The last set I'd got from Red's had two of the sixteen dead soft.
Kube is online now   Reply With Quote
Old 07-31-2023, 04:52 PM   #5
Ol' Ron
Ol' Ron's Avatar
When installing a cam in a "street" engine, regardless of the grind. I use stock springs with a .060 shim. Thisgives aprox 50LBs on the seat. Street engine rarely see more than 3500 rpm amd has on effect on the "rump rump"
Gramps
Old 07-31-2023, 08:19 PM   #6
Pete
I would NOT recommend using any mismatched parts.
You can have the cam reground.
I would use PROPERLY reconditioned stock steel lifters.
After listening to all of the adjustable lifter problems of the last few years, it may be impossible to get any that will last right now.
Some of the prblems of lifters I have seen come into my shop in the last 5 years:
1 - Loose screws.
2 - Wrong or no taper on face.
3 - Tapered barrel, some up to .004.
4 - Face not square with barrel.
5 - Uneven heat treat throughout especially on face.
6 - Undersize barrel by .003.
Old 08-01-2023, 05:25 AM   #7
big job
big job's Avatar
Said to say no more adjustable s for our builds.
big job is offline   Reply With Quote
Old 08-01-2023, 11:22 AM   #8
flatman
flatman's Avatar
Thanks for the advice. Looks like i have a few decisions to make.
