#1 |
Just broke my left rear axle shaft on my 47 sedan. I don't find one for a 47 on line but found this one from a 41 on line. Will it work OK?
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
#2 |
Super Moderator
I probably have NOS axle shafts or super nice used.
Interested? Or, are you thinking of replacing the entire rear assembly?
#3 |
Or, how about this 42-48 Ford/Mercury axle shaft? Would it work?
https://www.ebay.com/itm/17552368026...xoCGNYQAvD_BwE
#4 |
From memory the 41 is shorter? Needs to be 42-48 as I recall.
#5 |
That's what the green bible says too. 42-48 the same. Not 41.
#6 | |
#7 | |
#8 |
1932-1948 Ford Rear Axle Dimensions |
#9 |
I have those nos.
#10 |
Get a NOS axle from Fred Wilner or Kube and know for sure that you're dealing with the correct part in good condition.
Fred Wilner - (barnfind08") SOUTHSIDE OBSOLETE 7136 200th St E. Faribault, MN 55021 (507) 332-6789 Coop . |
#11 |
Which mountain were you climbing to break an axle ? Gotta be more to the story professor !
#12 |
I'm thinking the road up to the Gold King Mine in Jerome Arizona. ???
#13 | |
#14 |
Super Moderator
PM sent Craig.
#15 |
Craig,
Take up Kube or Fred's nos axle offer. It's a pretty straigt forward repair. Albiet, laborious. It might be worth installing a new axle seal while your that far into the job. |
#16 |
I'm betting the fracture that eventually failed that axle started long before that stop sign a mile from your home.
#17 |
Sorry for your troubles but to see you're still out and about in the old girl.
Making the simple complicated for over 30 years. |
#18 |
I’ve been having some pretty bad clutch chatter that may have contributed to it. Wish that was as easy to fix as replacing the broken axle.
#19 |
Old Henry, neither is an "easy" fix (depends on your pointof view. I believe you going to have to pull and open the rear end to change the axle. Pull the transmission and get the clutch, flywheel and pressure plate while your in that deep. Just my thoughts. LouB
#20 |
What LouB says.
Vern Tardel has a booklet on rebuilding the Ford banjo differential. https://www.verntardel.com/store/p30...ook_%2310.html
1910 Model T Touring 1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
