Old 06-06-2023, 07:41 PM   #1
Old Henry
Old Henry's Avatar
Default 47 ford rear axle
Just broke my left rear axle shaft on my 47 sedan. I don't find one for a 47 on line but found this one from a 41 on line. Will it work OK?
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 06-06-2023, 07:45 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: 47 ford rear axle
I probably have NOS axle shafts or super nice used.
Interested? Or, are you thinking of replacing the entire rear assembly?
Kube is online now   Reply With Quote
Old 06-06-2023, 07:46 PM   #3
Old Henry
Old Henry's Avatar
Or, how about this 42-48 Ford/Mercury axle shaft? Would it work?
https://www.ebay.com/itm/17552368026...xoCGNYQAvD_BwE
Old 06-06-2023, 07:48 PM   #4
1942deluxe
1942deluxe's Avatar
From memory the 41 is shorter? Needs to be 42-48 as I recall.
Old 06-06-2023, 07:58 PM   #5
Old Henry
Old Henry's Avatar
That's what the green bible says too. 42-48 the same. Not 41.
Old 06-06-2023, 08:23 PM   #6
petehoovie
petehoovie's Avatar
Old 06-06-2023, 08:29 PM   #7
petehoovie
petehoovie's Avatar
Old 06-06-2023, 08:39 PM   #8
mercman from oz
mercman from oz's Avatar
1932-1948 Ford Rear Axle Dimensions
Old 06-06-2023, 09:01 PM   #9
barnfind08
I have those nos.
barnfind08 is offline   Reply With Quote
Old 06-06-2023, 10:49 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by barnfind08 View Post
I have those nos.
Get a NOS axle from Fred Wilner or Kube and know for sure that you're dealing with the correct part in good condition.
Fred Wilner - (barnfind08")
SOUTHSIDE OBSOLETE
7136 200th St E.
Faribault, MN 55021
(507) 332-6789
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 06-06-2023, 11:31 PM   #11
cas3
Which mountain were you climbing to break an axle ? Gotta be more to the story professor !
Old 06-07-2023, 01:35 AM   #12
GB SISSON
GB SISSON's Avatar
I'm thinking the road up to the Gold King Mine in Jerome Arizona. ???
Old 06-07-2023, 08:10 AM   #13
Old Henry
Old Henry's Avatar
Gently, pulling away from a stop sign a mile from home.
Old 06-07-2023, 09:10 AM   #14
Kube
Super Moderator
Kube's Avatar
PM sent Craig.
Old 06-07-2023, 09:55 AM   #15
Seth Swoboda
Seth Swoboda's Avatar
Craig,
Take up Kube or Fred's nos axle offer. It's a pretty straigt forward repair. Albiet, laborious.
It might be worth installing a new axle seal while your that far into the job.
Seth Swoboda is online now   Reply With Quote
Old 06-07-2023, 10:01 AM   #16
JM 35 Sedan
JM 35 Sedan's Avatar
I'm betting the fracture that eventually failed that axle started long before that stop sign a mile from your home.
John
Old 06-07-2023, 10:04 AM   #17
51504bat
51504bat's Avatar
Sorry for your troubles but to see you're still out and about in the old girl.
Old 06-07-2023, 04:11 PM   #18
Old Henry
Old Henry's Avatar
I’ve been having some pretty bad clutch chatter that may have contributed to it. Wish that was as easy to fix as replacing the broken axle.
Old 06-07-2023, 04:33 PM   #19
Ford46
Ford46's Avatar
Old Henry, neither is an "easy" fix (depends on your pointof view. I believe you going to have to pull and open the rear end to change the axle. Pull the transmission and get the clutch, flywheel and pressure plate while your in that deep. Just my thoughts. LouB
Ford46 is offline   Reply With Quote
Old 06-07-2023, 05:08 PM   #20
mhsprecher
mhsprecher's Avatar
What LouB says.
Vern Tardel has a booklet on rebuilding the Ford banjo differential. https://www.verntardel.com/store/p30...ook_%2310.html
1910 Model T Touring
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
