Old 05-12-2023, 08:54 AM   #1
Anteek29
Anteek29's Avatar
Default Seat Belt Spacing?
I plan to install front seat lap belts in my '55 Vicky and want to know the recommended horizontal spacing for the anchor bolts?
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 05-12-2023, 05:03 PM   #2
GLAmes
GLAmes's Avatar
Default Re: Seat Belt Spacing?
When I do my '54 I plan to measure the spacing on my other vehicles.
'54 Skyliner. As close to original as I could restore it to.
GLAmes is offline   Reply With Quote
Old 05-12-2023, 05:52 PM   #3
miker98038
miker98038's Avatar
Since the 56’s came with optional belts, I’d guessing some were dealer installed. Those instructions will be out there someplace with the restoration guys. Should be close enough for a 55 or a 54. Crown Vic association maybe?
miker98038 is offline   Reply With Quote
Old 05-13-2023, 03:24 AM   #4
KULTULZ
KULTULZ's Avatar
Arrow Re: Seat Belt Spacing?
See if this helps in anyway - https://www.ssnake-oyl.com/
Get back if not.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 05-13-2023, 09:05 AM   #5
Anteek29
Anteek29's Avatar
Sorry...nothing helpful yet. I believe my answer will be to simply measure several installs at the next car show...no problem.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 05-13-2023, 11:32 AM   #6
KULTULZ
KULTULZ's Avatar
I have an INSTRUCTION SHEET here but it is pdf and the resolution is not that great.
Let me attach it to see if it comes through. CLICK on ATTACHED FILES.
The 1st gives the FORM PUBLICATION NOS from the ACCESSORY BELT KIT.
File Type: jpg SEAT BELT KIT (61200) 1953A- 1949-59 FORD CAR MPC TXT.jpg (21.5 KB, 17 views)
File Type: pdf SEAT BELT KIT (61200) - Install Instructions.pdf (112.6 KB, 18 views)
Old 05-13-2023, 01:41 PM   #7
dmsfrr
dmsfrr's Avatar
Double check underneath the floor before poking any holes from the top. Having the frame, brake or fuel lines in the way just won't do.
dmsfrr is offline   Reply With Quote
Old 05-13-2023, 06:57 PM   #8
Anteek29
Anteek29's Avatar
Dmsfrr...Duly noted, thanks!
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 05-14-2023, 01:23 PM   #9
Ole Don
Ole Don's Avatar
I placed the center of mine near the hump, thinking the curved metal may be stronger. The outers were just beyond where the frame is Big deal was holes in the carpet. never try to drill carpet. It will be a mess. Best to use a hole punch from your gasket making kit against a 2x4 under the carpet. If you don't have one, make an X with a new sharp razor blade.
Ole Don is offline   Reply With Quote
