Old 03-24-2023, 07:44 PM   #1
flatsforever
Default Power steering in '49 - '51 Fords
What are the best options for adding power steering to a stock 1951 Victoria? Can the factory '52 - '53 Ford / Mercury set up be adapted successfully? What mods are required?
flatsforever is offline   Reply With Quote
Old 03-24-2023, 10:25 PM   #2
CA Victoria
CA Victoria's Avatar
Default Re: Power steering in '49 - '51 Fords
Take a look at Borgeson.com
While on their site I noticed a kit for 49-5? Mercury.
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 03-24-2023, 10:47 PM   #3
cas3
I had a 50 Ford for a while, it drove like a dream compared to all the older cars I've had, just about a modern car IMHO
Old 03-25-2023, 09:48 AM   #4
Merc Cruzer
Merc Cruzer's Avatar
Good question, if the steering and suspension are the same, or similar, I would guess then it would be a definite possibility to install a factory 53' unit.
The complete units have become very hard to find and definitely are not cheap. You are looking at between $1,500 and $2,500 if you can find one. All of the parts, except one, are the same for the Merc and Fords (the idler arm mounting bracket).
Merc Cruzer is offline   Reply With Quote
Old 03-25-2023, 01:41 PM   #5
flathead4rd
flathead4rd's Avatar
Does not work with a flathead engine.
flathead4rd is offline   Reply With Quote
Old 03-25-2023, 02:54 PM   #6
TJ
TJ's Avatar
Why does it not work? 52-53 Fords and Mercs had flathead engines with power steering. or were you referring to the Borgeson unit? Your post was a little unclear.
Old 03-25-2023, 06:47 PM   #7
Merc Cruzer
That unit is on my 53' Merc with the 255 Flathead engine.
Old 03-26-2023, 09:22 AM   #8
5851a
Ford and Mercury/Lincoln went to new suspension I believe in 52. Borgeson.com says kit not recommended for flathead, not sure if it's frame clearance or difficulty of finding pulley's. You would have to call and ask.
5851a is offline   Reply With Quote
Old 03-26-2023, 09:38 AM   #9
Ol' Ron
Ol' Ron's Avatar
I used the 605 PS box Buick column and mad an adapter for the 70[s style pump. Got everything from a junk yard. The system is in my 47 KB1 with a 46/8 front axle ans suspension, Works pretty good. Mounting the pump was the hardest part.
Gramps
Old 03-26-2023, 04:39 PM   #10
flathead 53
I have power steering on my 53 f-100, bought the kit from CCP, bought the power steering bracket and pump on ebay ,pump is drivin off alternator .contact me for pictures if you want.
flathead 53 is offline   Reply With Quote
Old 03-27-2023, 11:47 AM   #11
flathead4rd
I was referring to the Borgeson unit. Sorry for the incomplete answer. Yes I'm aware of the 52 & 53 factory units but they are hard to find and very expensive.
Old 03-27-2023, 02:11 PM   #12
Merc Cruzer
But soooooo worth it, if you can find one.
