Old 03-14-2023, 03:21 PM   #1
smittyschmitz
Default adding rear seal to 39 block
rebuilding 1939/85 hp Ford but crank bad, have later version crank available which is not slinger style. Is there a way to add rear seal setup to my block or do I need to look for correct crnk?
smittyschmitz is offline   Reply With Quote
Old 03-15-2023, 12:30 PM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: adding rear seal to 39 block
Does your engine have the removable pot-mdetal seal plates in it? I believe it does.
If so, then you can replace the ones you have with the later ones that encompass the rear rope seals. You might contact Mac VanPelt - he probably has the plates.
Old 03-16-2023, 07:55 PM   #3
Ol' Ron
Ol' Ron's Avatar
You can also contact Red's headers. He had the converson to convert the slinger style Block to the later rope style. I used this to install a late 8BA crank in a 37 block.
Gramps
Old 03-16-2023, 08:09 PM   #4
Brian
Brian's Avatar
The diecast pieces you need are; 19B 6336 lower
91A 6335 upper
These will directly interchange with what's in your block now and allow you you fit a positive rear seal.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 03-16-2023, 09:05 PM   #5
Bored&Stroked
91A 6335 upper
Thanks Brian - I'm away from home, so I can't supply the details to stuff like this!
BTW: I would use the BestGasket's rear main seal kit - has a nice graphite impregnated rope seal and usually includes a small roll-pin that needs to be installed in the die-cast seal plate. The purpose is to keep the seal from spinning. If it has the roll-pin, make sure you install it. You'll need a drill-press and a small bit to partially drill down into the plate.
Follow the instructions!
Old 03-17-2023, 05:30 AM   #6
Mac VP
Mac VP's Avatar
Yes, we do have those seal retainers….
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
