Old 12-03-2022, 07:01 PM   #1
deuce295
deuce295's Avatar
Default AER Connecting Rods
I have Antique Engine Rebuilding inserted connecting rods and was curious if anyone has experience with those as far as knowing the torque for the rod cap bolts. They use a special bolt that looks like some type of specialized ARP bolt. Rich has sold the company to group in Indiana and I was having trouble getting a hold of them. Just curious if someone might know. Thank you.
deuce295 is offline   Reply With Quote
Old 12-03-2022, 07:49 PM   #2
J Franklin
J Franklin's Avatar
Default Re: AER Connecting Rods
Do you think they need a special torque? I wouldn't know a reason why?
Old 12-03-2022, 07:57 PM   #3
deuce295
deuce295's Avatar
I would assume it would be different since it is a small reduced shaft size shouldered 12 point bolt. Way different than stock. I’ll keep trying to get a hold of the new owners next week. Appreciate the reply.
Old 12-03-2022, 08:06 PM   #4
J Franklin
J Franklin's Avatar
Most rods torqued on most engines I have worked on were about 30-35# new or old.
Old 12-03-2022, 08:06 PM   #5
chrs1961815
chrs1961815's Avatar
45 pounds is what I recall from the guide.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 12-03-2022, 08:23 PM   #6
J Franklin
J Franklin's Avatar
What guide?
Old 12-03-2022, 08:57 PM   #7
johnneilson
Snyders has forged rods and the bolt tork is stated as 20ft#
That sounds low to me, but I typically use stretch dimension not tork
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 12-03-2022, 10:04 PM   #8
chrs1961815
Originally Posted by J Franklin View Post
What guide?
Rich's sheet he gave me with how to build an engine with AER parts.
Old 12-03-2022, 10:07 PM   #9
Doug Linden
Doug Linden's Avatar
35#ft is what Rich told me a number of years ago when i inquired about the torque of the connecting rod nuts.
Doug Linden is offline   Reply With Quote
Old 12-03-2022, 11:01 PM   #10
J Franklin
J Franklin's Avatar
I bet that is right. I think if I was worried about the rod nuts loosening I would use some LockTite instead of more force.
Old 12-04-2022, 01:49 AM   #11
BrianH
I have a set of B rods from AER and torqued them to 35lb ft.
BrianH is offline   Reply With Quote
Old 12-04-2022, 04:22 AM   #12
Dave in MN
Dave in MN's Avatar
35lb ft is correct. I have used them for years in the engines I rebuild.
Good Day!
Dave in MN is offline   Reply With Quote
Old 12-04-2022, 08:46 AM   #13
deuce295
deuce295's Avatar
Wow, lots of great info. I really appreciate everyone’s time and input. Sounds like 35lb is what I’m looking for.
Thank you everyone, hope you all have a great upcoming Christmas and New Year.
