I have Antique Engine Rebuilding inserted connecting rods and was curious if anyone has experience with those as far as knowing the torque for the rod cap bolts. They use a special bolt that looks like some type of specialized ARP bolt. Rich has sold the company to group in Indiana and I was having trouble getting a hold of them. Just curious if someone might know. Thank you.
Do you think they need a special torque? I wouldn't know a reason why?
I would assume it would be different since it is a small reduced shaft size shouldered 12 point bolt. Way different than stock. I’ll keep trying to get a hold of the new owners next week. Appreciate the reply.
Most rods torqued on most engines I have worked on were about 30-35# new or old.
45 pounds is what I recall from the guide.
"The more things change, the more they stay the same." |
Snyders has forged rods and the bolt tork is stated as 20ft#
That sounds low to me, but I typically use stretch dimension not tork John
As Carroll Smith wrote; All Failures are Human in Origin. |
Rich's sheet he gave me with how to build an engine with AER parts.
35#ft is what Rich told me a number of years ago when i inquired about the torque of the connecting rod nuts.
I have a set of B rods from AER and torqued them to 35lb ft.
35lb ft is correct. I have used them for years in the engines I rebuild.
Good Day! |
#13 |
Wow, lots of great info. I really appreciate everyone’s time and input. Sounds like 35lb is what I’m looking for.
Thank you everyone, hope you all have a great upcoming Christmas and New Year. |
