Old 10-11-2022, 10:23 AM   #1
poolplayer1
Default 55 Ford Ranch Wagon Wiper Motor.
Does anyone here have a wiper motor that I can buy from you? Mine is completely missing. I know I can switch over to a electric type motor but we don't get much rain here in AZ so I think the vacuum motor will be ok.
I saw a few on ebay but they are mostly for 55 ford trucks and I don't think they are the same because of the windshield size.
If no one has one, can somebody here that has a picture of the motor post it here so I can see what the wiper arm actuator on the motor looks like. I don't know the exact name of that part but its the one part on the motor that moves the wiper arms and blades.
Do you think the one from the 55 truck will fit my wagon?
I really think that a motor from any 55 ford passenger car will work on my wagon but not sure.
Thanks for your help as always.
poolplayer1 is offline   Reply With Quote
Old 10-11-2022, 10:47 AM   #2
Grim70
Default Re: 55 Ford Ranch Wagon Wiper Motor.
you can get a refurbished unit from concours.
https://www.parts123.com/parts123/yb...Z5Z5Z50000051e
Grim70 is offline   Reply With Quote
Old 10-11-2022, 11:14 AM   #3
51504bat
51504bat's Avatar
I converted my '54 Ranch Wagon to a 12 volt Newport Engineering unit. If I still have the old vacuum unit you can have it for postage if it will work for application. PM me if interested.
Old 10-11-2022, 11:33 AM   #4
56sedandelivery
56sedandelivery's Avatar
This is from my 56. You can have it for shipping. It fells snug moving the arm back and forth.
56sedandelivery is offline   Reply With Quote
Old 10-11-2022, 03:04 PM   #5
poolplayer1
Thanks to both of you for your kind offer. I think I will try the 56 model motor from 56 sedandelivery. I know that most parts between the 55 and 56 will work but don't know about the 54 but I will do a little research on that. 56 sedan, I sent you a PM. Can you please get back to me as soon as possible so I can get this motor from you.
Old 10-12-2022, 08:00 AM   #6
Ford blue blood
Ford blue blood's Avatar
55 was 6V and 56 12V?
Bill, certified Ford nut.
2024 F-150
2018 Lincoln MKZ
2016 Focus
1961 Comet S-22
1956 Ford Crown Victoria
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 10-12-2022, 10:10 AM   #7
poolplayer1
Thanks Ford Blue for your input. Years back I converted my wagon to a 12V system.
Old 10-12-2022, 06:56 PM   #8
paul2748
paul2748's Avatar
Correct, but the item in question is vacuum operated.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-13-2022, 01:24 AM   #9
Daves55Sedan
Daves55Sedan's Avatar
It doesn't matter which electrical system he has. The wiper motor is vacuum operated. Not a single spark required anywhere for the wiper motor to operate. I do hope you have a dual-action fuel pump though, in case you plan to do any highway driving in the rain or snow.
BTW, '55 and '56 wiper motors are identical for all full-size Ford cars and wagons. So either one will mount and work without any modifications.
Daves55Sedan is offline   Reply With Quote
Old 10-13-2022, 08:12 PM   #10
poolplayer1
Thanks guys for your good information. Daves55sedan, I have a question regarding the dual action fuel pump. Right now, there is no wiper motor at all. I am running a 302 with its fuel pump that is required and its running really good. If I get a vacuum wiper motor, Can't I just tap into the intake manifold to supply at least 15psi to that motor or will I need more vacuum than that? What is the purpose of a dual action fuel pump in my case?
Also, I think that there are 2 vacuum ports on the wiper motor, one on the top and one at the bottom. Can you tell me where this vacuum port hoses go to.
Thanks for all your help.
Old 10-13-2022, 08:44 PM   #11
dmsfrr
dmsfrr's Avatar
... If I get a vacuum wiper motor, Can't I just tap into the intake manifold to supply at least 15psi to that motor or will I need more vacuum than that? What is the purpose of a dual action fuel pump in my case?
Manifold vacuum may work the wiper motor, depending on its condition. The seals dry out with age.
The original dual action fuel pumps had a built-in vacuum booster as the top half of the fuel pump, to help the wiper motor work more consistently.
The hose fitting on top of the wiper motor next to the mechanical slide valve is for the vacuum line connection from the engine compartment. The 'fitting' on the bottom is an outside air inlet.
Service tip at this link...
https://www.ctci.org/gilsgarage/impr...iper-function/
dmsfrr is offline   Reply With Quote
Old 10-14-2022, 08:52 AM   #12
poolplayer1
Thanks dmsfrr for this information. I really appreciate your help.
Old 10-14-2022, 09:14 AM   #13
56sedandelivery
The one I have the slide valve part is reversed from the one in your pic. You can see it in the crappy pic I posted earlier.
Old 10-14-2022, 10:35 AM   #14
dmsfrr
dmsfrr's Avatar
Not surprised if the one in my photos isn't quite the same. It's from a '57 Bird not a 'full-sized' Ford car, and with the optional windshield washers.
