Old 08-19-2022, 10:20 AM   #1
stevests
stevests's Avatar
Default Master Cylinder Banjo Bolt sealant ?
Installed new copper washers on the Banjo bolt and after bleeding brakes, I have a very slight weep - I got it pretty darn tight - should I disassemble & replace the washers and use a sealant of some type ?
stevests is offline   Reply With Quote
Old 08-19-2022, 10:33 AM   #2
Krylon32
Default Re: Master Cylinder Banjo Bolt sealant ?
Try taking a small sharp bastard file and giving it a few strokes across the sealing surface on the master cylinder. This has been discussed here recently.
Krylon32 is offline   Reply With Quote
Old 08-19-2022, 10:39 AM   #3
tobby
annealing the copper washers should solve the problem, softening them, heat them red hot, submerge in cold water, be careful don't distort them, and re install......
tobby is offline   Reply With Quote
Old 08-19-2022, 12:23 PM   #4
stevests
stevests's Avatar
O.K. - thanks ! New master cylinder & copper washers.
Old 08-20-2022, 08:12 PM   #5
aussie merc
aussie merc's Avatar
make sure the brass fitting surfaces are flat and parallel it may have crushed in if some one has over tightened the bolt previously small amounts can be filed out but often they need to be replaced with the master
aussie merc is offline   Reply With Quote
Old 08-21-2022, 07:23 AM   #6
Mart
Mart's Avatar
No sealants should ever be used with brake components.
Mart is online now   Reply With Quote
Old 08-21-2022, 08:28 AM   #7
Bored&Stroked
Bored&Stroked's Avatar
As Mart noted, there is never any sealant of any type used with brake lines and associated components. Everything uses some sort of "crush" or "compression" type fit - whether it be a washer, the end of the tube/flare, etc..
Old 08-21-2022, 11:14 AM   #8
stevests
stevests's Avatar
Speed Bleeders come with a thread sealant ?
Old 08-21-2022, 03:48 PM   #9
rich b
rich b's Avatar
Guessing that is so there is no air leakage while bleeding; the bleeder actually seat and seal on the tapered end when tightened.
rich b is offline   Reply With Quote
Old 08-22-2022, 06:52 AM   #10
38coop
I had a leak on my 49. Used 2 of the copper gaskets and stopped my leak.
38coop is offline   Reply With Quote
