Old 08-18-2022, 07:37 PM   #1
ljaynavl
Default Trying to Pump Grease Into Non-Zerc Fittings
I've got some pressed-in old style fittings (both straight nozzle and conical shaped). I have what I think is an adapter tip for the lube gun. When I attempt to pump in some grease - say into the brake actuating arms - I don't think I'm getting anything pumped in. There is of course nothing to snap onto.
I'd appreciate an education on this 'art'!
ljaynavl is offline   Reply With Quote
Old 08-18-2022, 08:08 PM   #2
noboD
Default Re: Trying to Pump Grease Into Non-Zerc Fittings
Take that fitting out and use a regular fitting, fill with grease and then replace
noboD is offline   Reply With Quote
Old 08-18-2022, 08:09 PM   #3
Redbird
Redbird's Avatar
You have to go straight at the original fitting. Hold it straight with some force. I use an old Alemite grease pump on mine.
Redbird is offline   Reply With Quote
Old 08-18-2022, 08:18 PM   #4
Chris Haynes
Chris Haynes's Avatar
Changing fittings is simple.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 08-18-2022, 09:29 PM   #5
J Franklin
J Franklin's Avatar
Blasphamy!
Old 08-18-2022, 09:32 PM   #6
Gary WA
Gary WA's Avatar
Make sure fitting is clean of old grease!!! unplugged?
www.whidbeymodelaclub.com
Old 08-18-2022, 10:01 PM   #7
ljaynavl
These are pressed in fittings.
Old 08-18-2022, 10:43 PM   #8
Gary WA
Gary WA's Avatar
They will come out a little twisting.
Old 08-19-2022, 02:06 AM   #9
Synchro909
Synchro909's Avatar
The old style fittings rely on the pressure of you pushing the grease gun to seal. The same action pumps the grease. They don't need to be screwed in because the pressure also keeps them in. It is a whole different technique from what you guys call a Zerk (had to look that one up).
Hold the gun square and push - job done.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 08-19-2022, 05:20 AM   #10
shew01
shew01's Avatar
Replacing the original style fittings with zerks on my car was a pain. The reproduction fittings are very slightly larger and do not fit easily.
shew01 is offline   Reply With Quote
Old 08-19-2022, 06:01 AM   #11
Robert/Texas
Robert/Texas's Avatar
I agree with Redbird, my old Alemite grease gun works best for me. I found it via an internet search.
Robert/Texas is offline   Reply With Quote
Old 08-19-2022, 07:45 AM   #12
aermotor
You are aware that not all the repro. fittings are screw in fittings. Some that appear to have threads and are slightly larger are pound in with a slightly smaller socket than the wrench flats.
aermotor is offline   Reply With Quote
Old 08-19-2022, 09:50 AM   #13
GPierce
GPierce's Avatar
Here is what works for me on the original grease fittings. Usually a AI lead on EBay.
File Type: jpg CA138294-078D-4FC7-BE03-253BE6472151.jpg (11.7 KB, 45 views)
File Type: jpg 57158877-078B-4679-95BE-C3A66CB61678.jpg (15.6 KB, 34 views)
GPierce is offline   Reply With Quote
Old 08-19-2022, 09:51 AM   #14
Y-Blockhead
Y-Blockhead's Avatar
Usually the press in fittings don't have wrench flats. The vendors sell a tool for installing the press grease fittings. https://www.snydersantiqueauto.com/p...7846&cat=41753
File Type: jpg Screen Shot 2022-08-19 at 7.47.09 AM.jpg (5.0 KB, 107 views)
Old 08-19-2022, 09:56 AM   #15
Y-Blockhead
WHAT?? Use a tool that is actually designed to do the job... unheard of!!
Old 08-19-2022, 07:55 PM   #16
shew01
shew01's Avatar
Yes, that is true. They were still hard to install. I never really finished. I have about original and half zerks.
