I've got some pressed-in old style fittings (both straight nozzle and conical shaped). I have what I think is an adapter tip for the lube gun. When I attempt to pump in some grease - say into the brake actuating arms - I don't think I'm getting anything pumped in. There is of course nothing to snap onto.
I'd appreciate an education on this 'art'! |
Take that fitting out and use a regular fitting, fill with grease and then replace
You have to go straight at the original fitting. Hold it straight with some force. I use an old Alemite grease pump on mine.
Changing fittings is simple.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go?
www.whidbeymodelaclub.com |
These are pressed in fittings.
They will come out a little twisting.
The old style fittings rely on the pressure of you pushing the grease gun to seal. The same action pumps the grease. They don't need to be screwed in because the pressure also keeps them in. It is a whole different technique from what you guys call a Zerk (had to look that one up).
Hold the gun square and push - job done.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
Replacing the original style fittings with zerks on my car was a pain. The reproduction fittings are very slightly larger and do not fit easily.
Sent from my iPhone using Tapatalk |
I agree with Redbird, my old Alemite grease gun works best for me. I found it via an internet search.
You are aware that not all the repro. fittings are screw in fittings. Some that appear to have threads and are slightly larger are pound in with a slightly smaller socket than the wrench flats.
#13 |
Here is what works for me on the original grease fittings. Usually a AI lead on EBay.
#14 | |
#15 |
#16 | |
Yes, that is true. They were still hard to install. I never really finished. I have about original and half zerks. Sent from my iPhone using Tapatalk |
