Old 07-22-2022, 10:26 PM   #1
TonyM
TonyM's Avatar
Default Front seat won't lock in place
After re-installing my original equipment front seat in a stock 1937 Ford, I have discovered that it won't lock in place when adjusted. I took the seat out and observed that the seat handle blade was not falling fully in the notch that would hold it in place. I clamped the combination in place and forced the pieces back to their home positions and it seemed I had solved the problem. Got my car running and when backing into my garage the seat let loose. Lucky for me I was able to maintain control of the car.
I am going to remove the seat soon and try and solve this a second time. Have any members experienced this? I used the search feature to look for previous posts, but came up empty. Looking for any help. I guess I can bolt the seat into a single position, but I want to be able to operate the seat as intended. Looking for any help in solving this problem. Any help greatly appreciated.
Thanks.
File Type: jpg 293486696_2631409073661580_4602618427336025259_n (1).jpg (88.6 KB, 284 views)
TonyM is offline   Reply With Quote
Old 07-22-2022, 11:34 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Front seat won't lock in place
Originally Posted by TonyM View Post
After re-installing my original equipment front seat in a stock 1937 Ford, I have discovered that it won't lock in place when adjusted. I took the seat out and observed that the seat handle blade was not falling fully in the notch that would hold it in place. I clamped the combination in place and it seemed I had solved the problem. Got my car running and when backing into my garage the seat let loose. Lucky for me I was able to maintain control of the car.
Thanks.
Old 07-23-2022, 05:15 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
Lubrication,Lubrication,Lubrication to all locations that need it..
Old 07-23-2022, 07:10 AM   #4
Terry,OH
Terry,OH's Avatar
There may have been a spring that helped operate the handle into the detentes.
Old 07-23-2022, 09:55 AM   #5
1937sedandelivery
Here is a pic of the seat latching mechanism on my 37.
1937sedandelivery is offline   Reply With Quote
Old 07-23-2022, 11:37 AM   #6
petehoovie
petehoovie's Avatar
Old 07-23-2022, 05:45 PM   #7
TonyM
TonyM's Avatar
I clamped it like this and forced the pieces back to what I thought was the home position. It seemed to do the trick so I removed the clamp and re installed the seat. All good for a short drive. When I came home and backed into the garage, the seat let loose. Boy oh boy, but I was on it quick and disaster averted.
File Type: jpg 295623705_2640688372733650_2013799813459679491_n.jpg (47.6 KB, 217 views)
Old 07-23-2022, 05:47 PM   #8
petehoovie
petehoovie's Avatar
I clamped it like this and forced the pieces back to what I thought was the home position. It seemed to do the trick so I removed the clamp and re installed the seat. All good for a short drive. When I came home and backed into the garage, the seat let loose. Boy or boy, but I was on it quick and disaster averted.
Old 07-23-2022, 11:20 PM   #9
TonyM
TonyM's Avatar
Thanks.
File Type: jpg 295623705_2640688372733650_2013799813459679491_n.jpg (47.6 KB, 6 views)
Old 07-24-2022, 11:44 AM   #10
slowforty
The Tang that locks the seat in place may have broken off, Luckily I found a replacement piece. You may just have to lock it in place or find someone to rebuild the part,
slowforty is offline   Reply With Quote
Old 07-24-2022, 01:34 PM   #11
CHuDWah
CHuDWah's Avatar
I'd also suspect a broken spring - sometimes the break can't be readily seen without taking the mechanism apart. I imagine the spring is a fairly strong one. You might find a replacement at a hardware store, especially an old timey mom and pop shop rather than a big box chain. And yeah, lubricate all the moving parts.
CHuDWah is offline   Reply With Quote
Old 07-24-2022, 01:47 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
I believe that you're also going to find a latching mechanism on the passenger side, controlled by a rod running span-wise under the seat. Need to check that one out, too. Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 07-24-2022, 03:00 PM   #13
TonyM
TonyM's Avatar
Will do.
Thanks coop.
File Type: jpg 293486696_2631409073661580_4602618427336025259_n (1).jpg (88.6 KB, 20 views)
Old 07-24-2022, 05:42 PM   #14
Graeme / New Zealand
Graeme / New Zealand's Avatar
That little spring on the seat lever looks much the same as an accelerator pedal firewall spring.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 08-02-2022, 12:55 PM   #15
TonyM
TonyM's Avatar
Yes, the tab or tang that locks the seat in place is very wore down and not square where it should be. The piece will have to be replaced. In the meantime, I will have to bolt the seat in place somehow (without damaging the original equipment).
Old 08-02-2022, 12:57 PM   #16
TonyM
TonyM's Avatar
Latching mechanism on left side only.
I have found that the tab that locks the seat in place is very wore down and not square where it should be. The piece will have to be replaced. In the meantime, I will have to bolt the seat in place somehow (without damaging the original equipment).
Old 08-04-2022, 05:56 PM   #17
TonyM
TonyM's Avatar
The culprit is this worn tab on the seat handle locking mechanism.
Anybody got one laying around? LOL.
Old 08-04-2022, 06:39 PM   #18
V8COOPMAN
V8COOPMAN's Avatar
Tony....That piece could be bent-up and drilled out of a piece of strap in a half hour or less.
Coop
T5 W/TORQUE TUBE
Old 08-04-2022, 07:10 PM   #19
paul2748
paul2748's Avatar
Is it weldable steel so you can build it up and reshape to original?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-04-2022, 09:25 PM   #20
convert 40
Weld it up file the shape you need & re-harden it.
Rick
Napa, Ca.
convert 40 is offline   Reply With Quote
