Old 07-24-2022, 01:47 PM   #13
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Front seat won't lock in place
Originally Posted by CHuDWah View Post
I'd also suspect a broken spring - sometimes the break can't be readily seen without taking the mechanism apart. I imagine the spring is a fairly strong one. You might find a replacement at a hardware store, especially an old timey mom and pop shop rather than a big box chain. And yeah, lubricate all the moving parts.
I believe that you're also going to find a latching mechanism on the passenger side, controlled by a rod running span-wise under the seat. Need to check that one out, too. Coop
Click Links Below __
T5 W/TORQUE TUBE
