#1 |
Will I notice any differences in performance? Gas mileage , acceleration,,
What will the additional advance give me?
DON P |
#2 |
The 11A has a better advance curve. Must use in conjunction with the 11A weights.
#3 |
To change from the 40B to 11A you have to change the shaft, weights and the breaker plate. To me the advantage of using the 37-48 points is the best advantage of the conversion. The better advance curve helps but is not as drastic as people think.
#4 |
I made up a spare dist with the 11A shaft and the small points,installed it awhile back,
I couldn’t see any difference at the time,maybe install one then the other,might be able to feel the difference,,
DON P |
#5 |
Lawrie |
