Old 06-19-2022, 05:36 PM   #1
aussiesteve
Default 1940 column shift clip
Question guys.
The clip that goes on the top of the shift tube(under the steering wheel) came off on my coupe.
The factory diagram shows a part number of 7242.
Are these available repro?
Also the diagram show something under it,part no 351341-s.
This is a washer I assume.
But is it a wave washer or flat washer?
Thanks for the help
aussiesteve is offline   Reply With Quote
Old 06-19-2022, 06:07 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: 1940 column shift clip
Originally Posted by aussiesteve View Post
Question guys.
Thanks for the help
There is a thin wave washer beneath the circlip.
I don't believe they have ever been reproduced.
In the past, when I have needed one, I have utilized the clip that holds the brake lever to the shoe. I had to grind a bit of material from the top of the clip so it would fit the column.
Old 06-20-2022, 08:08 AM   #3
aussiesteve
Thank Kube.
I was thinking of using the brake lever clip.
I appreciate the help
