Old 06-12-2022, 05:17 PM   #1
Russell Reay
Russell Reay's Avatar
Default Gas valve filter
Time to put this back in the tank. The miner bees plugged the outlet hole, so I wish to take the valve apart to assure it is thoroughly clean. How is this pencil filter attached? Is it threaded down into the male fitting, or just push-fit? I prefer to know what I am doing before using a potentially wrong tool, then waiting several days and too much shipping charge for a replacement.
Russell Reay is offline   Reply With Quote
Old 06-12-2022, 05:34 PM   #2
Herb Concord Ca
Default Re: Gas valve filter
The Filter is just pushed into the valve, check to make sure it is soldered, if not it should just pull out.
Herb Concord Ca is offline   Reply With Quote
Old 06-12-2022, 06:24 PM   #3
ndnchf
ndnchf's Avatar
The pencil fitting spigot has a slight taper to wedge in the valve. The screen is only crimped into the fitting, so don't pull on the screen or it may come out.
ndnchf is offline   Reply With Quote
Old 06-12-2022, 06:38 PM   #4
Gene F
Gene F's Avatar
I took mine out after years of use, thinking it would need replaced. It was just fine. I still hosed it off with some spray carb cleaner.
Gene F is offline   Reply With Quote
Old 06-12-2022, 09:54 PM   #5
Redbird
Redbird's Avatar
If it does not swedge in, I just took a little tin foil and wrapped the bottom like putting on plumbers tape. It will take up the gap if any.
Redbird is offline   Reply With Quote
