Old 06-02-2022, 12:02 AM   #1
Granny
Default Flywheel limits
Guys could you please advise me the limits on how much you can machine of the face surface of flywheel the one I have has a groove in it.
The Flywheel came out of a 1948 ford pickup with a 10” clutch
Any advice will be appreciated, thank you in advance
Granny is offline   Reply With Quote
Old 06-02-2022, 12:11 AM   #2
Tinker
Tinker's Avatar
Default Re: Flywheel limits
Well the groove will probably not make a difference if it's a driver. Really.
Lighter flywheel is great for quick cars. Not great for cruisers really.
If the surface of the fly wheel is heat checked, it'll probably be fine with a light resurface.
Just my 2cents
Old 06-02-2022, 04:11 AM   #3
Mart
Mart's Avatar
I had a problem where the clutch disc was touching the flywheel bolts. If the flywheel were resurfaced it would make that worse.
Take too much off and you might get then same problem.
I don't know how much is too much.
Old 06-02-2022, 09:31 AM   #4
Bored&Stroked
Bored&Stroked's Avatar
There are a lot of flywheels out there . . . pretty much every one of us has a few stacked in the corner.
If you have any doubts about the resurfacing, bring it to a qualified engine machine shop and have them check it out. You might as well take a new clutch disk with you, along with the bolt plate and bolts - just in case they need to measure the distance to the flywheel bolts.
Posting some clear pics on this site might help us make a better judgement call.
Old 06-03-2022, 09:43 PM   #5
Granny
Bored&Stroked
I will take a photo over the weekend and try to post I have never posted a photo as yet
Old 06-03-2022, 09:43 PM   #6
Granny
Bored&Stroked
Old 06-04-2022, 12:50 AM   #7
48-710
G'Day Granny,
As Tinker has said a narrow,shallow grove won't worry a lot. The percentage of lost surface on a 10" plate is zip.I'ts a shame you are at the other end of the state as we machine all sorts of flywheels daily. I'm sure that you can find a good machine shop in your neck of the woods. Gary
48-710 is offline   Reply With Quote
Old 06-04-2022, 12:52 AM   #8
48-710
G'Day Granny,
As Tinker has said a narrow,shallow grove won't worry you a lot. The percentage of lost surface on a 10" plate is zip. I'ts a shame you are at the other end of the state as we machine all sorts of flywheels daily. I'm sure that you can find a good machine shop in your neck of the woods. Gary
Old 06-04-2022, 12:53 AM   #9
48-710
G'Day Granny,
As Tinker has said a narrow, shallow grove won't worry you a lot. The percentage of lost surface on a 10" plate is zip. I'ts a shame you are at the other end of the state as we machine all sorts of flywheels daily. I'm sure that you can find a good machine shop in your neck of the woods. Gary
Old 06-04-2022, 12:54 AM   #10
48-710
G'Day Granny,
Old 06-04-2022, 12:55 AM   #11
48-710
Woops what the hell happened there ????????
Old 06-04-2022, 01:30 AM   #12
Tinker
Tinker's Avatar
Glitch in the matrix.
Old 06-04-2022, 02:49 AM   #13
V8COOPMAN
V8COOPMAN's Avatar
TINKER in the matrix!
Coop/AMERICAN
Click Links Below __
T5 W/TORQUE TUBE
Old 06-05-2022, 10:02 PM   #14
Tinker
Tinker's Avatar
But yet I don't double post. I'm not a hobby, I hope, for you! I do find it amusing though.
Tinker/AMERICAN
