#1 |
Have an enclosed car hauler. I tie down the car on four corners to the D rings but still experience movement of the car sideways in the trailer. What can I do to prevent this? All ideas and pictures appreciated.
#2 |
Let some air out of the tires. I know it sounds lame, but it works.
#3 |
How are you attaching the tie downs to your car? hopefully not to the bumper’s or frame! I crisis cross the front and straight back on the rears attached to the axles. Some use two straps on each corner crisscross and straight!
#4 |
Are the straps on the wheels? That's where they should be. If they're tight at all 4 it shouldn't move. DOT technically requires 4 straps and 2 safety chains as I recall. I've never seen it done correctly by and AAA tow operators.
#5 |
Install the floor rail system with webs that go over the tires. It will never move!
#6 |
this was once discussed here int he past, with guys swearing they could just tie off at each corner. well your experience has shown otherwise...... |
#7 |
Whenever I trailer any of my cars I use the wheel straps, of course in a enclosed trailer it may be a bit of a struggle to get them on/off
#8 |
Why did the Titanic sink?
EXACTLY & discussed ad nauseam! LOL |
#9 |
I'll third the use of wheel nets. I put down E Track so I can move the attachment points as needed.
#10 |
I have an open trailer but I always use the criss-cross method and haven't had any issues.
