Old 03-18-2022, 01:20 PM   #1
dgkipp
Default Mechanical brakes dust cover
In the process of installing floater brake adjusters on my 35. Is there any trick on reinstalling the dust covers on adjuster?
dgkipp is offline   Reply With Quote
Old 03-18-2022, 01:42 PM   #2
deuce lover
deuce lover's Avatar
Default Re: Mechanical brakes dust cover
I leaned the cover a bit to wedge the edge in the slot,used a socket-just the right size then tapped it in.
deuce lover is offline   Reply With Quote
Old 03-18-2022, 02:29 PM   #3
dgkipp
I’ll give it a shot. Thanks.
Old 03-18-2022, 03:03 PM   #4
deuce lover
Hope you have woven linings.Mine were molded and I saw no improvement with the floaters.
Old 03-18-2022, 03:13 PM   #5
petehoovie
petehoovie's Avatar
Old 03-18-2022, 04:00 PM   #6
DavidG
DavidG's Avatar
In the photo it looks like one shoe has a molded lining and the other a woven lining.
Old 03-18-2022, 04:04 PM   #7
deuce lover
No David,All the shoes on my old '33 had molded linings.I think the brands were different.
Old 03-18-2022, 04:24 PM   #8
Lawrie
Lawrie's Avatar
Get a socket that is same diameter as the cup,sit the cup on it and use a large punch to punch the centre ,it will decrease the diameter for the cup and make for an easy install, then give it a few hits with a small ball peen Hamer on the centre to tighten it up
Lawrie
Lawrie is offline   Reply With Quote
Old 03-18-2022, 04:46 PM   #9
DavidG
DavidG's Avatar
I only use woven linings, at least through '36s. As I recall, the '37s use one of each per wheel.
Old 03-18-2022, 06:24 PM   #10
woodiewagon46
Sometimes parts of the locking groove break off so you may have to dimple the edge with a center punch after you get the cap in place. My friend had a noise in his rear and when he pulled the drum the dust/grease cap fell out. When we examined it the edge was broken in three places.I was amazed, but it didn't do any damage. I could just imagine the dust cap wedging itself between the shoe and the drum.
woodiewagon46 is offline   Reply With Quote
Old 03-10-2026, 08:27 PM   #11
[email protected]
johnr9q@yahoo.com's Avatar
I used my grinder to bevel the edge and then used a 15/16 socket and pounded it flush. I then used an 1/8" punch to push it down all the way.
1931 Model A Ford Slant Window
johnr9q@yahoo.com is offline   Reply With Quote
Old 03-11-2026, 06:38 AM   #12
Terry,OH
Terry,OH's Avatar
mine were so loose, I was afraid they would fall out so I used RTV around the edges.
