Old 03-06-2022, 05:33 PM   #1
kpfredericks
Default 30-31 Cowl Patch Panel
Does anyone know where I can find cowl patch panels 6 or 8"tall that replace the whole length ( front to back ) of the bottom of the cowl? All of the patch panels I can find don't have the front 2 inches where the " J " clips for the cowl lacing hook.
Thank you in advance
Ken
kpfredericks is offline   Reply With Quote
Old 03-06-2022, 07:09 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: 30-31 Cowl Patch Panel
Part # A-014-BD Model Year 30-31
Have you looked to the vendors? The above is from Snyder’s online catalogue
Most others carry them. Not sure/don’t think they are 8” but height can be added easier that the profiles. There are full cowl panels made by Brookville. What body style are you repairing?
To go that high cowl must be in trouble.
Oldbluoval is offline   Reply With Quote
Old 03-06-2022, 07:21 PM   #3
Dale G.
Dale G.'s Avatar
Stipe used to make some very nice ones, full length with cowl band holes, matching bead. Ouarter panels match bead.
Dale G. is offline   Reply With Quote
Old 03-06-2022, 07:42 PM   #4
kpfredericks
Thank you for responding.
I am working on a 1930 pickup. If I could replace the bottom 6 inches i would be happy.
I had forgotten about Sniders. Theirs are the front 2 inches either.
I may have to find the cash for the full length ones.
Old 03-06-2022, 07:48 PM   #5
Oldbluoval
Oldbluoval's Avatar
You are correct about the front 2”..no one making that.
I’d bet someone on here has a rotten cowl that the pieces you need can be cannibalized from. I currently do not have such around here.
Then they could be spliced to repop metal.
Old 03-06-2022, 07:51 PM   #6
kpfredericks
Thank you Dale G.
I looked in google for Stipe, but did not find anything.
Where would I find Stipe full length, or patch panels?
Are they the ones that Brookville sells?
Old 03-06-2022, 08:17 PM   #7
john charlton
john charlton's Avatar
Generally the front 2" does not rot out . The front 2" is a complex pressing and difficult connection so I leave this piece in situ and make a vertical cut behind it . I do not use the full patch panel height and cut back to the good cowl panel . The lower area is more stiff so easy to set the right curve . An easy fix not complicated .
John in sunny Chandler AZ.
john charlton is offline   Reply With Quote
Old 03-06-2022, 08:21 PM   #8
kpfredericks
Thank you Oldbluoval
I will study on those ideas.
Ken
Old 03-06-2022, 08:29 PM   #9
kpfredericks
Thank you John.
My Front 2" is damaged, and rusty on both sides. I may have to find a cowl that I can cannibalized.
Old 03-06-2022, 09:07 PM   #10
Oldbluoval
Oldbluoval's Avatar
Many vendors sell Stipe panels…..unless they’re out.
The link I posted with Snyder’s is his I think.
You can call and the vendor will tell you if they are his.
Old 03-07-2022, 09:09 AM   #11
Dave1931Pickup
Check your private message's I can send you pictures of mine.
Dave1931Pickup is offline   Reply With Quote
Old 03-07-2022, 09:44 AM   #12
kpfredericks
Dave,
I cant send private messages yet.
I look forward to seeing your pictures.
Ken
Old 03-07-2022, 09:51 AM   #13
CA Victoria
CA Victoria's Avatar
Very close to original but as with most all patches they must be fitted to your body panel.....
Try Bert’s Model A
File Type: jpg 5D2200F1-EB76-44D1-87EE-AB6022545666.jpg (8.2 KB, 31 views)
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 03-07-2022, 09:57 AM   #14
kpfredericks
Thank you Dave
Old 03-07-2022, 10:00 AM   #15
kpfredericks
Thank you CA Victoria
Old 03-07-2022, 10:01 AM   #16
kpfredericks
Thank you Tim
