Old 11-12-2021, 10:21 PM   #1
dmaxweb
dmaxweb's Avatar
Default Oil Drain Tube Thread Size
The hole in the rear bearing cap is 1/8-27 NPT. The tubes sold by the vendors are 3/8-32 UNF..
Should they be the same?
dmaxweb is offline   Reply With Quote
Old 11-14-2021, 11:29 AM   #2
Glenn Thoreson
Glenn Thoreson's Avatar
Default Re: Oil Drain Tube Thread Size
Ford used two different sizes of these tubes. The one the vendors have is the later version meant to cure a problem with clogging, etc. You may have to search for a used one or drill and tap the cap for the larger tube.
Glenn Thoreson is offline   Reply With Quote
Old 11-14-2021, 12:10 PM   #3
Benson
Berts has both sizes of drain tubes...
https://modelastore.com/index.php?ro...&category_id=0
NOTE: Most main caps I see have a SMALL tack weld so it will not fall off.
You have to be sure when gas welding or brazing not to melt the babbit in the main cap.
Maybe an engine builder will comment on whether Mig or Tig is better.
Benson is offline   Reply With Quote
Old 11-14-2021, 04:21 PM   #4
dmaxweb
dmaxweb's Avatar
I checked with Steve and the 3/8" tube has 3/8-32 thread not pipe thread.
Ora at Schwalms recommended red loctite.
Old 11-15-2021, 01:00 PM   #5
katy
katy's Avatar
Get a piece of 1/8 pipe and make your own drain tube.
Old 05-22-2023, 10:41 PM   #6
Mike34s
[url]https://modelastore.com/index.php?route=product/search&search=drain%20tube&category_id=0[/url retro bowl
The most important is still the gas welding stage, right?
Mike34s is offline   Reply With Quote
Old 05-23-2023, 07:18 AM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Steve is correct. Just for clarity, the early A-6325-AR Cap's hole was threaded 5/16-32.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-24-2023, 12:04 AM   #8
Manuel
What size were the B pipes?
Manuel is offline   Reply With Quote
