Old 06-07-2021, 05:38 AM   #1
totto
totto's Avatar
Default What color are valve covers for 1957 292?
What color are valve cover for 1957 292 engine and what is the correct engine color?
totto is offline   Reply With Quote
Old 06-07-2021, 09:48 AM   #2
cb
Default Re: What color are valve covers for 1957 292?
The valve covers are black, engine block ford red, air cleaner argent silver.
cb is offline   Reply With Quote
Old 06-07-2021, 07:56 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
Typical for '55, '56 & 57 Ford cars and maybe other years as well, the valve covers, oil filler cap, coil mounting bracket, crankcase vent tube & oil filter cannister were high temperature gloss black. The engine block castings were Ford red/orange high temperature enamel. The air cleaner housing was painted Ford Argent silver.
Some of the repro auto parts suppliers still sell the official Ford Argent silver in spray cans and Ford red in both spray cans and quart containers. Fairly decent high temp black is sold at many chain auto parts stores in spray cans. Be sure to apply a coat of high temp primer on the stamped steel parts prior to applying overcoat.
Daves55Sedan is offline   Reply With Quote
Old 06-09-2021, 04:19 AM   #4
totto
totto's Avatar
THANKS guys for the info; just got a 1957 Country Squire with 292 and has blue valve covers. Block red/orange and air cleaner is silver.
Old 06-09-2021, 07:41 PM   #5
Gene F
Gene F's Avatar
Mine has the Thunderbird decals on both valve covers. The Thunderbird Special ones go on the "real" 312s.
Gene F is offline   Reply With Quote
Old 07-10-2021, 11:26 PM   #6
slumlord44
Correct, if you really want to dress it up go with the T Bird cast aluminium valve covers. The most beautiful factory valve covers ever made in my opinion.
slumlord44 is offline   Reply With Quote
Old 07-10-2021, 11:40 PM   #7
dmsfrr
dmsfrr's Avatar
Originally Posted by slumlord44 View Post
... if you really want to dress it up go with the T Bird cast aluminium valve covers. ...
just Fyi, the pair of rocker arm studs that hold each cast aluminum valve cover in place are approx 1/4" (or 3/8" ?) taller than the studs for sheet metal valve covers.
dmsfrr is offline   Reply With Quote
