Old 06-01-2021, 11:28 AM   #1
stewgee
stewgee's Avatar
Default Shock needle valve
Can someone tell me how to determine what needle valve I need for a 30 Roadster shock? I know it's not the pointer one. That was used only on 1928 A's.The square head was used until October of 1930. The hex head was used from November 30 until the end of A production. How do I tell what time frame my A falls in? Thanks
stewgee is offline   Reply With Quote
Old 06-01-2021, 11:45 AM   #2
Brentwood Bob
Default Re: Shock needle valve
The frame number, if original, will indicate the build date of the frame.
Brentwood Bob is offline   Reply With Quote
Old 06-01-2021, 11:52 AM   #3
stewgee
stewgee's Avatar
Thanks Brentwood Bob. So where should I look for the frame number? I assume it's original since it had a frame off restoration completed in 2015.
Old 06-01-2021, 12:25 PM   #4
Brentwood Bob
Vin should be same.
https://www.fordbarn.com/forum/attac...3&d=1622303011
Old 06-01-2021, 06:31 PM   #5
stewgee
stewgee's Avatar
Engine number is A4128761. How can I determine the build date of the car from this number? Also how does one know if this is not a replacement engine.
Old 06-01-2021, 08:00 PM   #6
shew01
shew01's Avatar
Lift the body slightly off the frame and *hope* the number (from the photo above) is readable.
shew01 is offline   Reply With Quote
Old 06-01-2021, 09:30 PM   #7
Brentwood Bob
Try a rubbing , lead pencil and paper. Several sources for engine numbers and monthly ford production records. The hard part is verifying the frame stamping. If you have the interest the judging standards are sold by the parts houses and show the numbers I believe.
Old 06-01-2021, 11:42 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
Vince Falter's Ford Garage has a lot of info on engine numbers (and most everything else!!) http://www.fordgarage.com/pages/ABenginenumbers.htm
According to the chart your engine is from November 1930?
