Old 12-15-2020, 01:14 PM   #1
NoahVail
Default Which throw out bearing for 1961 Galaxie T85
This is for a 1961 Galaxie Sunliner 292 w/ T-85; I assume it's a std duty clutch. I believe the clutch has low miles. We're getting some squeak from the clutch area that goes away when the clutch pedal is depressed. This car sat for years and I suspect the bearing has dried up.
Rock Auto is giving me some visually different throw out bearings for our application. I need help zeroing in on one.
(note: I've never bought a "self aligning" throwout bearing. Not sure if that's just a preference thing or not.)
The part description for the below image says: "Bearing Assembly Thrust Type; with Standard Duty Clutch; Thru 10 inch disc"
This next one says: " Bearing Assembly Sealed Self-Aligning; with Standard Duty Clutch; Thru 10 inch Disc"
Next one says: "Bearing Only; with Standard Duty Clutch; Thru 10 inch Disc"
Last one: "Assembly; Standard Clutch"
Recommendation?
EDIT: Image 2 and 4 seem to be the same part.
Is image 1 the same (or a minor variant of) as 2 & 4?
NoahVail is offline   Reply With Quote
