#1 |
Hi gents-
how are the nuts, bolts, and washers installed on my "48 ford rear fender? Is the flat washer and bolt pushed up from the wheel well? |
#2 | |
Super Moderator
The "nuts" are actually special clips integral of the body. And, if I recall correctly, the lower one on each side is a caged nut.
#3 |
fenders came off. |
