Old 12-11-2020, 10:52 AM   #1
RAYSSUPERDELUX
Default Rear fender install
Hi gents-
how are the nuts, bolts, and washers installed on my "48 ford rear fender? Is the flat washer and bolt pushed up from the
wheel well?
RAYSSUPERDELUX is offline   Reply With Quote
Old 12-11-2020, 11:23 AM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: Rear fender install
Originally Posted by RAYSSUPERDELUX View Post
Hi gents-
wheel well?
Yes. Flat washer, lock washer and hex bolt from the outside - inward.
The "nuts" are actually special clips integral of the body. And, if I recall correctly, the lower one on each side is a caged nut.
Old 12-11-2020, 03:25 PM   #3
RAYSSUPERDELUX
Kube- thanks for the info, as soon as I read I remembered how the
fenders came off.
