#1 |
going to install a metal heater hose adaptor/fitting into the front lower radiator hose. other than making a nice tight hole does one use any type of sealer on the flat surfaces
thanks a bunch Frederic [email protected] |
#2 | |
Super Moderator
This stuff has been around for decades for good reason.
#3 |
Also, I believe it was "Kube" who told me when I asked, angle it towards the fender, NOT verticle, so the fan doesn't hit the hose.
Paul in CT |
#4 |
Last one I installed was probably 15 years ago, I might have put some RTV on there if I recall. It probably doesn't really need anything. It's still been leak free.
#5 |
Choose a hole punch that creates a nice round snug fitting to the pipe. You can experiment on a flat piece of rubber like an old radiator hose, inner tube or something to find the right punch if you have one of those sets that goes from maybe 1/8 to 3/4 inch. I haven't had one of those ever leak without a sealant but the Indian Head Shellac is a good idea.
#6 |
#7 |
Here is photo of the orientation on a V8 85 '40 Ford. The fan clears the hose by about 3/8", and the fitting angle makes for gradual bed in the heater hose.
#8 |
Use a step drill to drill the hose and permatex2 to seal the parts and threads. Works very well.
#9 |
Thanks all
Good ideas, some times the “simplest” appearing jobs can have the most complicated process. Frederic |
