#1 |
Any one eles wonder why the walker 2" chopped 32 radiators top water openings are so small? I was possibly thinking about getting something made up to get back to stock size, anyone eles using one?
what did you do? Thanks |
#2 |
I'd contact Walker and see what's up. May be a mistake in assembly
#3 |
Exactly the same as my recent Walker aluminum rad. Top connections really small..... But when you think of cooling 239 cu in, perhaps more volume than a competitor's 235 six by a long shot.... ???
#4 |
That is the same size the 8BA and 8RT thermostat housings are.
I’m going thru that right now. I put a ‘53 Ford motor in a ‘46 Mercury. The fthermosts use 1 1/8” hoses, the radiator takes 1 3/4”. I solved the problem by getting special thermostat housings from Bob Drake. They are 1 3/4”. |
#5 |
And my aluminum radiator is actually a champion, but 1 1/8" top hoses.
#6 |
#7 |
Oops; sorry wrong info for this application.
#8 |
Thanks for the reply everyone. Glad to see it's not just me thinking they are overly small
#9 |
When you order a Walker radiator for a flathead they usually ask if you are running early or late heads for the top inlets and they do 1 1/8th for late heads and 1 3/4 for early heads. Bottom outlets are always 1 3/4. I've ordered dozens of them for customers without problems
#10 | |
