Old 12-08-2020, 10:29 PM   #1
rust revival
Default Walker 32 radiator. Water neck openings why so small?
Any one eles wonder why the walker 2" chopped 32 radiators top water openings are so small? I was possibly thinking about getting something made up to get back to stock size, anyone eles using one?
what did you do? Thanks
rust revival is offline   Reply With Quote
Old 12-08-2020, 10:55 PM   #2
fordor41
fordor41's Avatar
Default Re: Walker 32 radiator. Water neck openings why so small?
I'd contact Walker and see what's up. May be a mistake in assembly
fordor41 is offline   Reply With Quote
Old 12-08-2020, 11:54 PM   #3
GB SISSON
GB SISSON's Avatar
Exactly the same as my recent Walker aluminum rad. Top connections really small..... But when you think of cooling 239 cu in, perhaps more volume than a competitor's 235 six by a long shot.... ???
Old 12-08-2020, 11:58 PM   #4
Aarongriffey
That is the same size the 8BA and 8RT thermostat housings are.
I’m going thru that right now.
I put a ‘53 Ford motor in a ‘46 Mercury. The fthermosts use 1 1/8” hoses, the radiator takes 1 3/4”.
I solved the problem by getting special thermostat housings from Bob Drake.
They are 1 3/4”.
Aarongriffey is offline   Reply With Quote
Old 12-09-2020, 12:03 PM   #5
GB SISSON
GB SISSON's Avatar
And my aluminum radiator is actually a champion, but 1 1/8" top hoses.
Old 12-09-2020, 12:11 PM   #6
Tony, NY
I have the same on my Walker. Had to put a sleeve in the hose to get down to that size. A piece of another smaller hose.
Tony, NY is offline   Reply With Quote
Old 12-09-2020, 02:43 PM   #7
rich b
rich b's Avatar
Oops; sorry wrong info for this application.
Old 12-09-2020, 06:44 PM   #8
rust revival
Thanks for the reply everyone. Glad to see it's not just me thinking they are overly small
Old 12-09-2020, 07:53 PM   #9
Krylon32
When you order a Walker radiator for a flathead they usually ask if you are running early or late heads for the top inlets and they do 1 1/8th for late heads and 1 3/4 for early heads. Bottom outlets are always 1 3/4. I've ordered dozens of them for customers without problems
Krylon32 is offline   Reply With Quote
Old 12-10-2020, 02:01 PM   #10
Tim Ayers
This with me as well.
