Old 12-08-2020, 08:35 PM   #1
OldGold360
Default Frame rust
Well I bought another frame for my ‘36 pickup over the weekend to replace the rusty one I had only to find rust in my new rust free frame when I got home. I know I can repair the rust, however, with the limited time I have to work on my own stuff I had hoped to just spend the money and get a frame without rust, saving myself some time. Now, basically back in the same boat, I am looking at options.
Does anybody know if someone makes repair pieces for this section of the frame, or does anybody have a junker frame with the passenger rear corner in good, useable shape that they’d sell?
I figured it wouldn’t hurt to ask. Thanks
File Type: jpeg 2487017A-6406-44D0-9638-0EE149E237CF.jpeg (110.2 KB, 257 views)
File Type: jpeg D552C667-E7AD-4153-B116-11EC2B3699D5.jpeg (101.2 KB, 257 views)
Last edited by OldGold360; 12-08-2020 at 09:30 PM. Reason: Added vehicle year and model
OldGold360 is offline   Reply With Quote
Old 12-08-2020, 09:23 PM   #2
Zeke3
Zeke3's Avatar
Default Re: Frame rust
I am not aware of anybody making repair sections for the back corner of the frame. Joe's Antique Auto Parts in Mass. is offering some frame repair sections for the area in front of the rear axle and maybe some other pieces.
It would be good if you told us what year/model your vehicle is.
Zeke3 is offline   Reply With Quote
Old 12-08-2020, 09:32 PM   #3
OldGold360
I checked out Joes to see if they had these pieces but the closest piece is the rear crossmember. Thanks for the suggestion. I did add the vehicle year and type in my original post. Sorry about that.
Old 12-08-2020, 10:01 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
Looks bent and mangled too
As long as you didn't pay xtra for it the rust is free
Old 12-08-2020, 10:50 PM   #5
OldGold360
It needs completely replaced on that corner. It’s bent/mangled only because it so heavily rusted in that corner. I should’ve looked closer at the frame.
Old 12-09-2020, 08:57 AM   #6
4tcoupe
I have the remains of a '35 pass. frame, let me check and I'll get back with you.
John
4tcoupe is offline   Reply With Quote
Old 12-09-2020, 09:17 AM   #7
OldGold360
Thank you very much John.
Old 12-09-2020, 09:24 AM   #8
skidmarks
skidmarks's Avatar
35 to 40 frames are notorious for rot.
Can you cut it out of your other frame?
skidmarks is offline   Reply With Quote
Old 12-09-2020, 09:40 AM   #9
JSeery
JSeery's Avatar
35 to 41 pickup frames are all similar, so that might give you a wider range to look at.
Old 12-09-2020, 10:20 AM   #10
OldGold360
It’s not really any better on my other frame.
Old 12-09-2020, 10:22 AM   #11
OldGold360
Thank you.
Old 12-09-2020, 10:48 AM   #12
36ford7
I agree with this 100%, as mine was rusted as well.
Bruce
1936 Ford 5W Coupe
36ford7 is offline   Reply With Quote
Old 12-09-2020, 01:56 PM   #13
T Scott
Unless you are trying to be 100% original I would think any decent fab shop could make that repair.
T Scott is offline   Reply With Quote
Old 12-09-2020, 03:33 PM   #14
OldGold360
Good thing for me I own a metalshaping/fab shop. I just wanted to avoid any additional work on my end but it looks like I’ll just have to make that section of the frame unless something turns up. I don’t think I’m going to hunt down another frame. Thanks
Old 12-09-2020, 08:14 PM   #15
alanwoodieman
it would be hep full to tell people where you are located. as stated above 35 to 40 car and to 41 pick up frames are very similar
alanwoodieman is offline   Reply With Quote
Old 12-09-2020, 08:23 PM   #16
OldGold360
Ok, thanks. I thought it showed my location when I signed up. Regardless, I added it to my profile. I’m not too sure how that will help my situation. As of now I am planning to just form the pieces I need to replace. The only reason why I bought a new frame was to avoid spending the time repairing the frame. I think at this point I just need to find the time and fix it and move on. I was hoping someone was making this section, but I couldn’t find it, so I asked you fine folks. This is something that should be made since it’s obviously a common area to rust out.
If someone has this chunk of frame, I’ll buy it. If not, I’ll post some photos of the repair hoping it can help someone in my same situation. Thanks
Old 12-09-2020, 08:34 PM   #17
4tcoupe
I looked at my frame parts, the last 20" on driver side main frame is good, the "x"member part is rough, the same parts on pass. side are rough., do not have rearmost crossmember. If you are interested and it is warm enough for my wife & her cell phone tomorrow, I'll have her send you some pictures. Parts are free, you pay shipping from zip code 74601.
John
(PS) Any body have any use for a '49 thru 51' Merc ( pedals thru floor), rolling frame? Same price and deal.
Old 12-09-2020, 09:15 PM   #18
OldGold360
Thanks John. I appreciate that. I’ll send you a PM with my contact so that you can shoot me some pictures if it’s convenient.
Old 12-11-2020, 08:16 PM   #19
OldGold360
Today I decided to make the necessary pieces to repair the rust in my otherwise rust free frame. I still need to clean up the surface rust before I weld the pieces in place, and either source rivets or machine them.
File Type: jpeg 5ABA2CFE-0AB9-467D-B757-77205D73B1B4.jpeg (102.1 KB, 117 views)
Old 12-11-2020, 08:50 PM   #20
Zeke3
Zeke3's Avatar
Great looking repair panel!
