Old 12-08-2020, 01:22 PM   #1
caf
caf's Avatar
Default jigs for painting fat fenders
Anyone have any clever ideas on ways they hung there fat fenders for spraying..I have some square stock was going to weld some thing up off this dolly,,,,thanks ahead
caf is offline   Reply With Quote
Old 12-08-2020, 01:51 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: jigs for painting fat fenders
I made a pair of "saw horses". They are taller than a typical saw horse and have a pair of curved boards on each end to hold the fender securely.
I (first) paint the insides of the fenders by placing them in a common paint rack. Once they dry and I have wet sanded and buffed the insides, I tape up (insides) and place them on the horses.
Repeat
I can get you a photo tomorrow if you like.
I should have thought of these years ago as they have made my life much easier.
Kube is online now   Reply With Quote
Old 12-08-2020, 02:11 PM   #3
caf
caf's Avatar
Hi Kube ,,that would be great when u get a chance to post the photos,,sounds like you had the fastened very secure to be able to also sand and buff,,Iv had my hands full wrestling these around just doing the bodywork and sanding the primer,,I don't paint every day so it is important for me to have these set secure at a comfortable height ,,,thanks much jim
Old 12-08-2020, 02:43 PM   #4
Kube
Super Moderator
Kube's Avatar
I'll get the photos ASAP. Probably tomorrow as they are outside and I don't think I'll get there until after dark.
Old 12-08-2020, 04:12 PM   #5
19Fordy
19Fordy's Avatar
"Once they dry and I have wet sanded and buffed the insides, I tape up (insides) and place them on the horses."
Wow! That is truly a pro a work.
Old 12-08-2020, 05:19 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
I've heard that Kube had even color-sanded and buffed the back side of the dash, the passenger side of firewall, and I THINK even the inside of the roof on this coupe back when. Even the inside of doors get the full resto and paint treatment on a "Kube" restoration. The guy is an ANIMAL! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 12-09-2020, 10:37 AM   #7
Kube
Super Moderator
Kube's Avatar
Okay, here's the photo's I'd promised. Don't laugh - they really work well. Of course they are padded prior to utilizing. Note the one end is a mirror opposite of the other saw horse to compensate for the left vs. right fender.
They are about 4' tall which makes them about perfect for my old back.
Okay, now you can laugh
Old 12-09-2020, 10:38 AM   #8
Kube
Super Moderator
Kube's Avatar
What you heard is true. I'd only done that "inside the body" thing twice.
I'm doing my best to get the "crazy" under some control.
Old 12-09-2020, 10:43 AM   #9
36ford7
This is a great idea.
Bruce
1936 Ford 5W Coupe
36ford7 is offline   Reply With Quote
Old 12-09-2020, 10:49 AM   #10
caf
caf's Avatar
Hi Kube... you described them well that's how i pictured them yesterday after reading your post,I was thinking 3/4 plywood but better yet looks like you shaped it out of a piece of 2 by 8.. I can use the inner fenders for a pattern,,,thanks much
Old 12-09-2020, 10:50 AM   #11
Kube
Super Moderator
Kube's Avatar
Hi Kube... you described them well that's how i pictured them yesterday after reading your post,I was thinking 3/4 plywood but better yet looks like you shaped it out of a piece of 2 by 6.. I can use the inner fenders for a pattern,,,thanks much
I'm sure plywood would work just as well. I had the 2" x 6" stock so used it.
Old 12-09-2020, 03:40 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
Well, I'm not laughing.....I'm disappointed! From "THE Kubarth", I was expecting no less than properly trimmed, shaped, sanded, stained, and then hand polished wooden 'art'.....something akin to this saddle stand pictured below. Neat horses though, that certainly should serve function quite well. DD
T5 W/TORQUE TUBE
Old 12-10-2020, 09:03 AM   #13
old31
Very clever.
