Old 10-28-2020, 12:40 PM   #1
adileo
adileo's Avatar
Default 52 F1 oil seal
Hi guys
Workin on replacing the oil seal. I’m having difficulty getting old one out & the part looks different than what’s up on truck. Is there a cap that covers oil seal? It’s not shown in shop manual.
File Type: jpeg 7319356A-2F98-4E0F-8F8B-433A40EE119C.jpeg (27.3 KB, 56 views)
File Type: jpg 675C77DF-1CCC-4EC2-BD3E-9BD7B3965858.jpg (43.0 KB, 39 views)
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 10-28-2020, 01:20 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 52 F1 oil seal
There are a few different oil seals, which one are you talkin' about?
Old 10-28-2020, 01:52 PM   #3
adileo
adileo's Avatar
Thanks- The part number is M-4676.
Is there a deflector / cap over it? If yes is it presses on or screw in. See pic to left above.
Thanks
Andy
1952 F1
Old 10-28-2020, 02:01 PM   #4
Bob C
The shop manual doesn't show a deflector, just the seal and companion flange.
Old 10-28-2020, 02:06 PM   #5
adileo
adileo's Avatar
I know but maybe this rear was changed out. See pic it has a cap - deflector or something I can’t get off....
Thanks
Andy
1952 F1
Old 10-28-2020, 02:19 PM   #6
alanwoodieman
changed out mine on my 49 F1-new one looks just like yours
alanwoodieman is offline   Reply With Quote
Old 10-28-2020, 02:25 PM   #7
adileo
adileo's Avatar
How did get the plate or seal out?
Do I need the deflector if I destroy it getting it out?
Thanks
Andy
1952 F1
Old 10-28-2020, 03:47 PM   #8
alanwoodieman
drill two hole on opposite sides--run a large sheet metal screw in and pry out seal using the alternate holes. always remember the "edge" of the seal goes against the fluid side
Old 10-28-2020, 03:53 PM   #9
Bob C
What deflector? Are you asking about the oil slinger that's behind the seal?
Old 10-28-2020, 04:00 PM   #10
adileo
adileo's Avatar
No please see pic on left. It’s in front
Thanks
Andy
1952 F1
Old 10-28-2020, 04:16 PM   #11
51 MERC-CT
51 MERC-CT's Avatar
Does the pic on left show the shield and bearing in place with the axle removed?
Old 10-28-2020, 04:20 PM   #12
adileo
adileo's Avatar
Hi no
The pic shows the view with drive shaft, companion flange & nut removed.
Thanks
Andy
1952 F1
Old 10-28-2020, 04:35 PM   #13
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by adileo View Post
Hi no
This now becomes a little clearer (it's the pinion shaft seal not an axle seal)
It should pry off utilizing the outer seam.
Old 10-28-2020, 04:51 PM   #14
adileo
adileo's Avatar
This from shop manual:
File Type: jpeg 5F921D6D-F476-4A31-A803-B1ED691E1164.jpeg (25.4 KB, 22 views)
Thanks
Andy
1952 F1
Old 10-28-2020, 05:35 PM   #15
adileo
adileo's Avatar
Thanks all! It was confusing that the replacement didn’t look like what I was seeing on the truck. What I’ve gathered is the old original seal had a metal lip. The replacement doesn’t and it’s not needed. So I can now hack at it tomorrow.
Thanks
Andy
1952 F1
Old 10-28-2020, 06:07 PM   #16
JSeery
JSeery's Avatar
Just remember you're messing with the pre-load on the pinion. Need to mark the nut well and be sure it gets back to the same location.
Old 10-28-2020, 06:23 PM   #17
adileo
adileo's Avatar
Jerry thanks. I didn’t mark it. The book says tork 140-180.
Two questions. Since I still haven’t removed the oil seal. Should I put the nut and yoke back tork and mark? Or too late and just tork to specs?
Thanks
Andy
1952 F1
Old 10-28-2020, 06:46 PM   #18
JSeery
JSeery's Avatar
I think it's to late to correct it now. For future reference, always mark a pinion nut before you remove it. The torque spec is all you have to go on now, most likely will be ok.
Old 10-28-2020, 06:59 PM   #19
adileo
adileo's Avatar
My bad. Thanks!
Thanks
Andy
1952 F1
Old 10-28-2020, 08:23 PM   #20
Ross F-1
Ross F-1's Avatar
I would absolutely go with torque to specs rather than the position the nut was in 68 yrs ago when it had brand new bearings. Although you may end up backing off to get the cotter pin in.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
