Old 07-18-2020, 11:42 AM   #1
sunshine
sunshine's Avatar
Default Crabb dist.setup pictures ??
Does anyone have a picture they could share of the wires connected..This on a. 47 Truck so it is not stock I cannot find a picture in a search. Thank You BOB
sunshine is offline   Reply With Quote
Old 07-18-2020, 12:04 PM   #2
38bill
38bill's Avatar
Default Re: Crabb dist.setup pictures ??
Here is a link to VanPelts website. It shows the dist and plug wiring. The crab dist is the same as the stock '47 dist with the exception of the cap, cap clips and the rotor.
http://www.vanpeltsales.com/FH_web/f...str-timing.htm
38bill is offline   Reply With Quote
Old 07-18-2020, 02:34 PM   #3
sunshine
sunshine's Avatar
Thank you. Bill . I just want to see how the wires are configured going in to the crabb cap , with a 90 or straight in . I am trying to use my stock looms . How are the 3 and 5 configured which as you know cross over . Thanks BOB
Old 07-18-2020, 02:41 PM   #4
JSeery
JSeery's Avatar
Are you wanting it original or just functional?
Old 07-18-2020, 08:09 PM   #5
sunshine
sunshine's Avatar
Thank you Seery I have 47 truck it should have the rabbit ear type cap .which has been on the truck for 18. Years . It started having shorts in the wires . So I decided to change to Crabb. BOB
Old 07-18-2020, 08:14 PM   #6
oldford2
oldford2's Avatar
I quess you should explain "Having shorts on the wires"
John
oldford2 is offline   Reply With Quote
Old 07-18-2020, 10:49 PM   #7
38bill
38bill's Avatar
Here is a photo of my not stock 59AB with crab distributor.
Old 07-18-2020, 10:59 PM   #8
cas3
looks pretty darn nice there bill!
cas3 is online now   Reply With Quote
Old 07-18-2020, 11:51 PM   #9
Tinker
Tinker's Avatar
Sunshine, I'm not sure the issue. Run them as best as you can.
Old 07-19-2020, 12:38 AM   #10
V8COOPMAN
V8COOPMAN's Avatar
Here's a picture with wire ends. Note numbered wire outlets in order of firing. Cam (distributor) rotates counter clockwise looking at distributor from front. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-19-2020, 02:43 AM   #11
Tinker
Tinker's Avatar
Even the new caps have numbers. 4 looks a bit off.
Old 07-19-2020, 05:54 AM   #12
sunshine
sunshine's Avatar
38 Bill and coop man Thank You very much for the pictures . That’s exactly what I wanted to see .
Old 07-19-2020, 06:10 PM   #13
Ken/Alabama
Ken/Alabama's Avatar
3&5 crossover.
File Type: jpg ED945BB2-5BC9-46FE-87E5-9211931314C8.jpg (42.3 KB, 102 views)
Ken/Alabama is offline   Reply With Quote
Old 07-19-2020, 06:11 PM   #14
JSeery
JSeery's Avatar
Originally Posted by Ken/Alabama View Post
3&5 crossover.
That is a nice clean setup.
Old 07-19-2020, 06:38 PM   #15
Ken/Alabama
59A with 4 1/4” stroke x 3 5/6” bore , Isky 400 jr cam. I built the engine and installed it in a 32 Sedan Delivery chassis. Body is getting painted.
File Type: jpg 93E4AF7A-AC62-4D51-9D20-F1A0E35702A6.jpg (60.6 KB, 206 views)
Old 07-19-2020, 07:28 PM   #16
V8COOPMAN
V8COOPMAN's Avatar
Ken....That sure is an interesting-looking exhaust header. Beautiful detail work! DD
T5 W/TORQUE TUBE
Old 07-19-2020, 11:55 PM   #17
38bill
38bill's Avatar
Those straight boots look great.
Old 07-20-2020, 11:46 AM   #18
sunshine
sunshine's Avatar
Ken Ala that sure looks nice . My problem is the engine is in a 47 pkp.and am standing on my old head at 83 but I will get it done , might not look quiet so good . Just so it works . I know I shouldn’t be doing this at my age THANKS everyone for the help BOB
Old 07-20-2020, 02:31 PM   #19
Mart
Mart's Avatar
I found the 90 degree end fittings work well. Mine has the truck pumps that have the belt further forward. Clearing the pulleys with straight terminals is tricky. 90 deg fittings let them run up and keep them out of the way.
Old 07-20-2020, 02:58 PM   #20
JSeery
JSeery's Avatar
Hang in there, you'll get it!
