Old 07-14-2020, 04:29 PM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default Crab distributor 6v to 12v
So on the original system 6v positive earth the resistor gives approx 3.5 v to distributor points. Then change to 12v negative earth coil is changed to 12v but distributor can still remain also existing condenser remains.
The reason the distributor does not need to be changed out is? Less amps with 12v?
Keen for an explanation on this one.
thanks
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 07-14-2020, 04:31 PM   #2
Mart
Mart's Avatar
Default Re: Crab distributor 6v to 12v
So the reason the distributor does not need to be changed is... I dunno, it just doesn't.
Old 07-14-2020, 05:13 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
There are no components inside the distributor that are voltage-sensitive. And, anything that MIGHT be current-sensitive is not threatened because OHM's Law would reduce the effects of any current involved, like small gauge wires and the sizing of connection hardware. The points don't care about voltage. The coil and any resistors are the only items requiring consideration with a voltage change..... IGNITION-wise! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-14-2020, 05:19 PM   #4
Phil Gillespie
Originally Posted by V8COOPMAN View Post
There are no components inside the distributor that are voltage-sensitive. And, anything that MIGHT be current-sensitive is not threatened because OHM's Law would reduce the effects of any current involved, like small gauge wires and the sizing of connection hardware. The points don't care about voltage. The coil and any resistors are the only items requiring consideration with a voltage change. DD
Thanks for that. So would the original resistor need to be changed or is this dependant upon primary resistance of 12 v coil in use ie 3 ohms?
Phil NZ
Old 07-14-2020, 05:31 PM   #5
FlatheadTed
FlatheadTed's Avatar
the original resistor would need to be changed , a Botch S002 R coil is a good one to use in conjunction with a 12 volt common resistor reducing to approx 8 Volt , Repco or auto stop .Pan pacific ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 07-15-2020, 01:59 AM   #6
Phil Gillespie
So now have a 12v coil which states on box external resistor required.
This I take that I will need a total of approx 3ohms, coil plus resistor.
Phil NZ
Old 07-15-2020, 03:24 AM   #7
Tinker
Tinker's Avatar
Points and coil still need 4 volts. 1957 ballasts in the system will work. coil restiance makes up the difference. Ford ran 6 volt dizzies on 12 volts after 1954. Just used a ballast coil resistance and a ballast.
https://www.tractorpartsasap.com/coi...IaAn7zEALw_wcB
Old 07-15-2020, 03:43 AM   #8
Phil Gillespie
https://www.ebay.com/itm/NEW-1932-48...53.m1438.l2649
this is what I need from 3rd Generation a 12v coil with 3.3 ohms primary resistance yes?
Just want it simple without an external resistor
Phil NZ
Old 07-15-2020, 08:21 AM   #9
Jack Shaft
Points are just a switch,not resistance sensitive.
3 ohms resistance means its a 12v coil
1.5 ohms resistance means its a 6v coil
Bosch blue coil,35k output,designed to run without resistor,cheap on amazon.
Jack Shaft is offline   Reply With Quote
Old 07-15-2020, 10:16 PM   #10
JSeery
JSeery's Avatar
Phil, you just need somewhere in the range of 3 ohms in the system. So 1.5 ohm coil + 1.5 ohm resistor OR a 3 ohm coil without a resistor. These numbers are just the general range, the 3.3 ohm coil would be fine.
Old 07-16-2020, 12:10 AM   #11
Phil Gillespie
Yep thats what I'm aiming at. Just thought a 12v 3ohms would save the need for external resistor. Can get one locally in NZ.
Phil NZ
Old 07-16-2020, 12:13 AM   #12
35fordtn
35fordtn's Avatar
Phil, the coil we sell 3.3 ohm is a oil filled version of the Bosch 00012 coil. You certainly should be able to find one local and save on the transit cost. They were commonly used on Volkswagens
35fordtn is offline   Reply With Quote
Old 07-16-2020, 02:14 AM   #13
Phil Gillespie
Michael,
Yes was aware of the one you carry, and that was also my thinking about locating local and saving on transit.
Phil NZ
