Old 05-24-2010, 02:20 PM   #1
36coupe3w
36coupe3w's Avatar
Default George "Skip" Haney Water pumps
Just got a set of rebuilt Skip water pumps. The job is professional looking and response time was great. George is certainly an asset to the flathead community. Thanks again for a great job
Bill
36coupe3w is offline   Reply With Quote
Old 05-24-2010, 02:50 PM   #2
Scott/Mn
Scott/Mn's Avatar
Thumbs up Re: George "Skip" Haney Water pumps
I second this comment. Skip also did good work on the water pumps for my '36 coupe! Scott
Scott/Mn is offline   Reply With Quote
Old 05-24-2010, 03:41 PM   #3
uncle max
uncle max's Avatar
Default Re: George "Skip" Haney Water pumps
Four pair here. Never looked back...
uncle max is offline   Reply With Quote
Old 05-24-2010, 04:14 PM   #4
Brendan
Brendan's Avatar
i just had him rebuild a coil for my 36 truck, good service and fast turnaround!
Brendan is offline   Reply With Quote
Old 05-24-2010, 04:17 PM   #5
1938 Woody Cape Cod
1938 Woody Cape Cod's Avatar
Five coils all great......Bob
1938 Woody Cape Cod is offline   Reply With Quote
Old 05-24-2010, 04:34 PM   #6
oldford2
oldford2's Avatar
2 sets of pumps and one coil. They work! And if you are ever in Florida it is a great shop to visit. If GM is "hanging around" you are in for a treat viewing his Fords. John
oldford2 is offline   Reply With Quote
Old 05-24-2010, 04:39 PM   #7
Cecil/WV
Cecil/WV's Avatar
2 sets of pump and 1coil for me. Very good!!
Cecil/WV is offline   Reply With Quote
Old 05-24-2010, 04:47 PM   #8
Lawson Cox
Lawson Cox's Avatar
One coil for me. It works great. Fires up as soon as I hit the switch.
Old 05-24-2010, 04:51 PM   #9
flathead4rd
flathead4rd's Avatar
If you got a flathead you gotta get his pumps. Even Henry would approve.
flathead4rd is offline   Reply With Quote
Old 05-24-2010, 05:22 PM   #10
HOTRODSURFER
HOTRODSURFER's Avatar
his pumps are the cats pajamas!
HOILER AUTO REPAIR est 1918
https://www.facebook.com/pages/HOILER...16725868370435
HOTRODSURFER is offline   Reply With Quote
Old 05-24-2010, 09:11 PM   #11
Joe AZ
Joe AZ's Avatar
Bill
Can anyone provide Skip's contact information? Joe
Joe AZ is offline   Reply With Quote
Old 05-24-2010, 09:20 PM   #12
Cecil/WV
Cecil/WV's Avatar
[email protected]
Old 05-24-2010, 09:32 PM   #13
Joe AZ
Joe AZ's Avatar
Thanks Cecil....Joe
Old 05-24-2010, 09:40 PM   #14
FL&WVMIKE
FL&WVMIKE's Avatar
Skip also markets an overflow pipe valve. It keeps water from being thrown out the overflow pipe on trips, etc. My '35 was bad about getting hot, being that the water would keep getting lower, the longer I drove it. Now, with his pumps and valve, I have no heating problems at all.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 05-25-2010, 03:11 PM   #15
JM 35 Sedan
JM 35 Sedan's Avatar
Bill
__________________________________________________ ______________
I just received my set of Skip Haney rebuilt '37-'48 Ford water pumps as well. I mailed these to Skip Monday before last, May 17, Priority Mail, Flat Rate Box and received them back yesterday, Monday, May 24th. He did an absolute beautiful job on these pumps. See pictures attached. And guess what......they fit my 59ab engine perfectly. No need to worry about holes not being cast or reamed correctly because they are the original 78-_ _ _ _ pn, made in the USA pump housings, and not the alternative made in China versions that are being sold by all the big, well known vendors. They will also cool the engine better than the original pumps and are guaranteed for 5 years or more. They came with two new gaskets and an instruction sheet on how/what to do to get max cooling from these high flow water pumps. What more could you ask for and where else would you get this kind of service or turn around time? If you need water pumps for your Flathead, do yourself a favor and send your old cores to Skip for a rebuild. You will not be sorry you did. JM
John
Old 05-25-2010, 03:17 PM   #16
dbrock
Got my water pumps done and rebuild distributor on my '36 last year....It doesn't get any better than Skip !!!!
dbrock is offline   Reply With Quote
Old 05-25-2010, 03:41 PM   #17
40LUV
40LUV's Avatar
He rebuilt my coil and set the rebuilt distributor I already had. Started the car for the first time last night after installing the parts and it fired right up. I'm looking forward to a summer where the car will start when it's hot.
40LUV is offline   Reply With Quote
Old 06-02-2010, 07:12 PM   #18
36 coupe
Banned
I am 36 coupe an never used Skips water pumps.I rebuild my own with kits i bought from the Ford garage for 2 bucks each in the50s.
36 coupe is offline   Reply With Quote
Old 06-02-2010, 07:25 PM   #19
Ken Crans
Ken Crans's Avatar
Hey Fellas,How much for a orig. pair rebuilt from a 8ba, would you estimate in cost? thanks Ken Nice Job, i hear he's the best!!
Ken Crans is offline   Reply With Quote
Old 06-02-2010, 09:14 PM   #20
JM 35 Sedan
Just wondering if you also rebuilt the water pump on that Model A powered saw mill. that you frequently mentioned on the old Fordbarn, that always over heated? I don't think Skip rebuilds model A pumps or I would recommend sending that one to him for rebuild along with a set of your '36 pumps. JM
John
