Old 05-30-2020, 02:29 PM   #1
53_mercLuke
Default 1953 Flathead acceleration issue
I just rebuilt my holley teapot carburetor and it runs great at idle but when I give it 1/4 to 1/2 throttle it spits then dies. The float looks level from the top. I replaced the fuel filter and the pump is mechanical but not that old. I also replaced the distributor cap and rotor and the vacuum advance on it to eliminate that from being a possible issue. Any other thoughts?
Thanks
53_mercLuke is offline   Reply With Quote
Old 05-30-2020, 02:48 PM   #2
hotrodart
hotrodart's Avatar
Default Re: 1953 Flathead acceleration issue
Sounds like the accelerator pump is not working. There should have been a new one in the rebuild kit. Make sure it has a snug fit in the cylinder. Also make sure you put in the check-ball to allow the pump to make pressure.
hotrodart is offline   Reply With Quote
Old 05-30-2020, 04:35 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Try moving the pump adjustment to the hole that is farthest from the shaft center line.
Old 05-30-2020, 04:53 PM   #4
Merc Cruzer
Merc Cruzer's Avatar
Accelerator pump, picture attached.
Prior posts may give you a few hints, as to correct float and fuel levels:
https://www.fordbarn.com/forum/showt...ht=float+level
https://www.fordbarn.com/forum/showt...vel+carburetor
Merc Cruzer is offline   Reply With Quote
Old 05-31-2020, 12:45 PM   #5
53_mercLuke
Update on my running issue:
I moved the pump adjustment over to the right from the middle and it helped alittle. But I also found the diaphragm from the kit for the power valve was another shorter then the original so luckly i saved the old one and put it in and now its running like a champ. Thanks for the help guys
