Old 05-09-2020, 04:21 PM   #1
293131
Default 1951 Ford overdrive transmission identification??
Hello all,
I am posting this for my dad. I bought in an eBay auction a '49-'50 OD and supposedly a '51 Ford overdrive.
Could someone take a look at these pictures and let me know if it is indeed a '51? It's going to the shop on Monday to get rebuilt so I'd rather find out for sure before then!! If you need more pics, please let me know.
This is supposed to go in a '51 Custom convertible.
Many, many thanks.
293131 is offline   Reply With Quote
Old 05-09-2020, 05:09 PM   #2
petehoovie
petehoovie's Avatar
Default Re: 1951 Ford overdrive transmission identification??
Looks like your its missing some parts...
FORD 3 SPEED 1951-53 MERCURY TRANSMISSION W/R10 OVERDRIVE
Old 05-09-2020, 05:16 PM   #3
293131
Pretty obvious that it's missing parts, yes. What I'm asking is if it indeed is a '51. This is measured from the front. Are parts still available to make this complete?
Thank you!
Old 05-09-2020, 05:19 PM   #4
petehoovie
petehoovie's Avatar
From what I'm seeing, yes, it is a '51....
Old 05-09-2020, 05:19 PM   #5
293131
Thanks!!
Old 05-09-2020, 05:21 PM   #6
petehoovie
petehoovie's Avatar
This guy will have the parts you need > http://vanpeltsales.com/FH_web/trans...BW-ODparts.htm
You definitely need this > https://www.ebay.com/itm/Borg-Warner...kAAOSw7GBeVn87
Old 05-09-2020, 07:28 PM   #7
billfish
billfish's Avatar
I discovered from a past search that the location of the rear mount to the frame on the 51 overdrive trans is not in the same location as the 49 and 50.
billfish is offline   Reply With Quote
Old 05-10-2020, 09:04 AM   #8
293131
Thanks again. Do you know if the convertible overdrive was any different than any of the other models that were produced? I guess the Vanpelt outfit can answer that.
Also, could the side plate arms from a '49/'50 work on the '51? Finally, what would a '49-'50 overdrive be worth? Untested.
Thanks again.
Old 05-10-2020, 09:45 AM   #9
tubman
tubman's Avatar
The convertible uses a different solenoid than the rest of the line. They are quite difficult to find. I seem to remember to have seen articles where someone has converted a regular solenoid for use in a convertible.
Old 05-10-2020, 09:50 AM   #10
rotorwrench
rotorwrench's Avatar
The clutch mount on the left side is Ford just before swing pedals in 1952. It sets lower on the 1951 Ford and late 1951 Mercury transmissions than the 1949 or 50 Ford set up does. I can't see the rear trans mount since none of the photos show it. If it has diamond cut gears then it is definitely 1951 or later.
The convertible used the rocker contraption that fits underneath the transmission.
http://www.vanpeltsales.com/FH_web/F...ngpawlassy.jpg
Old 05-10-2020, 09:55 AM   #11
philipswanson
The 51 transmission had a different pitch on the gear teeth so don't mix the 49-50 gears with the 51 gears.
philipswanson is offline   Reply With Quote
Old 05-11-2020, 06:57 AM   #12
Frank Miller
Frank Miller's Avatar
While I cannot speak for subsequent years this is at least a 51 because it does not have the machined opening for the reverse lockout switch. I do not think you need the solenoid relocation mechanism on the 51 as quite a bit changed on the frame crossmember that ear due to the addition of the automatic transmission. If you do I have one I would part with.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
