Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 02-04-2011, 05:50 AM   #1
CountrySquire55
CountrySquire55's Avatar
Default Epoxy sealant for leaking gas tank?
Reposted in correct forum.
Last edited by CountrySquire55; 02-04-2011 at 06:03 AM. Reason: Posted in wrong forum.
CountrySquire55 is offline   Reply With Quote
Old 02-06-2011, 12:08 AM   #2
1952henry
1952henry's Avatar
Default Re: Epoxy sealant for leaking gas tank?
Try SEAL-All, available in hardware stores.
http://www.eclecticproducts.com/sealall.htm
My neighbor used it on a leaking Ford pickup gas tank. It did the trick. I use it on the jet well plugs on rebuilt carburetors.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 02-06-2011, 03:30 AM   #3
ken ct
Whats this "seal all" stuff.Ive been using "lock-tite 222" for this same thing.Expensive as you know around $12 a tiny little bottle??? Any cheaper also use it on float screw on stroms. ken ct. Send PM if you want.
ken ct is offline   Reply With Quote
Old 02-06-2011, 03:46 PM   #4
1952henry
1952henry's Avatar
Click on the link in my post. I've used it on jet well plugs as stated, also on the Stromberg float pins. I've also used Permatex High Tack 80062 for the same thing.
http://www.permatex.com/products/Aut...et_Sealant.htm
Bad thing about Permatex stuff, it is purple and VERY sticky!! Hard to get off if you goof.
