Old 02-08-2020, 09:21 PM   #1
Kpar
Kpar's Avatar
Default 33 rear bearings
Removed rear bearings from hub and somebody before me must have removed them in a somewhat aggressive manner. The cage has been damaged possible when driving out the seals, they were then replaced with the damaged side to the bottom of the hub.They are ford bearings should I try & grind off the damage ?
Kpar is offline   Reply With Quote
