Old 01-09-2020, 04:54 PM   #1
Bill Dewey
Default 600/16 Tires
I need new tires for stock 1936 Ford coupe. I was looking at Goodyear deluxe all-weather, I think it is a good lookin tire (white wall) . I would like to know what brand is the best and where to get. Thanks Bill
Bill Dewey is offline   Reply With Quote
Old 01-09-2020, 06:00 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: 600/16 Tires
I put 600/16 Diamondback Auburn radials on my 40 wagon and it drives like a new car! Since I no longer need to be point judged, I took the bias ply tires off. These look very much like stock tires and am happy with them.
Old 01-09-2020, 10:56 PM   #3
philipswanson
Yes but too pricey.
philipswanson is offline   Reply With Quote
Old 01-10-2020, 12:35 AM   #4
deuce_roadster
Phillipswanson, they were cheaper then the 5 Ford Script double wide whitewall bias ply tires I got from Coker (which are no longer being made). I will never use bias ply tires on any of my cars I drive since the wagon was the only one I built to be judged.
Old 01-10-2020, 07:17 AM   #5
Steve in Denver
Steve in Denver's Avatar
Too bad Coker does not make a double white wall 6.000x16 radial. From looking at their youtube, starting about 3:20, https://www.youtube.com/watch?v=7IsSwmR8bck they just need to apply another layer of whitewall on the inside.
Steve in Denver is offline   Reply With Quote
Old 01-10-2020, 08:16 AM   #6
Bored&Stroked
Bored&Stroked's Avatar
I use Excelsior Stahl Sport Radials on my 32 Cab . . . they are a great tire (though expensive). They have about the best "look" for a radial that I can get . . . but obviously are not bias plys. You pay for them . . . but it is worth it in my mind.
I will not run bias-ply tires on a car that I will operate on the freeways/interstate at traffic-flow speeds. Safety is a big issue for me - as our old cars are already quite unsafe as compared to everything around us - so I try to improve my handling, braking and wet-weather 'roadability' as much as possible.
Once you switch over to a quality radial, you'll never go back to bias ply . . . unless you have a dang good "judging" reason to do so.
Old 01-10-2020, 09:32 AM   #7
V8COOPMAN
V8COOPMAN's Avatar
I've been a huge advocate of the Excelsior Stahl Sport Radials for a couple of years now. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-10-2020, 12:57 PM   #8
Seth Swoboda
Seth Swoboda's Avatar
Originally Posted by philipswanson View Post
Yes but too pricey.
Tire's are never cheap, I don't disagree.
Seth Swoboda is offline   Reply With Quote
Old 01-10-2020, 12:58 PM   #9
Seth Swoboda
A friend has these on a '35 Tudor. They look good and ride nice.
Disclaimer* They may not be for everyone's budget.
Old 01-10-2020, 01:07 PM   #10
VeryTangled
VeryTangled's Avatar
I run the Auburn's and yes they were, I'd say, very pricey. One thing I noticed is that the spare tire disc is a lot of work to get to fit. I'd buy them again.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 01-10-2020, 01:32 PM   #11
Seth Swoboda
Jeff is right on. If you have a spare tire cover it will be a tight fit because the 6.00 x 16 radial tire profile is a tad bigger than bis ply. One solution is to keep a bias ply for the spare and run the radials.
Good observation Jeff an important item to point out.
Old 01-10-2020, 11:50 PM   #12
JM 35 Sedan
JM 35 Sedan's Avatar
Jeff, I'm wonder what pressure you're running in that spare tire, and have you tried lowering that pressure enough to allow an easier fit of the tire cover?
John
Old 01-11-2020, 11:00 AM   #13
tom/illinois
I tried this on a '35 and it was still a very tight fit for the spare tire cover.
* this is Seth and I just realized I was logged in under my dad's name on his PC.
tom/illinois is offline   Reply With Quote
